Ignition Switch problem
Pugzilla
Post by Pugzilla on Sun 31 Jan 2016, 11:52 pm
For some reason recently, my ignition switch has developed a serious fault. I can only turn on the power when the key is 10-40 degrees counterclockwise to the 'ON' position. If the key slips into the 'ON' position then the power goes and the engine is dead. I could see this causing me to crash if it happens mid corner.
BIke has 34k miles if that is of any use.
Anyone know what's going on here?
Re: Ignition Switch problem
Post by wornsprokets on Mon 01 Feb 2016, 6:35 am
This happened in my fireblade, its corrosion from water, wd40 into barrell with key in, on off load of times, i took top yoke off to get at electrical connections , fireblade ignition is in two parts i left key barrell and changed electrical connection under neath , connectipns were green u mite get away cleaning them
Post by eternally_troubled on Tue 02 Feb 2016, 1:14 pm
I would agree that the key-switch can wear and certainly can take on water, so a good spray of WD-40 and some on/off action would be a good start.
If that doesn't fix it then you should check for loose and corroded connections (also as mentioned above).
If all of that doesn't fix it then you'll probably need a 'new' (or at least 'working') ignition switch. Might be worth using a multimeter on the old one to check that it is really broken.
As an interim measure you could install a (hidden) switch that bypasses the key-switch so the bike will at least stay 'on' when you want it to!
    Current date/time is Sun 24 Jun 2018, 12:02 pm
