off with the tank
off with the tank
Post by skyrider on Thu 07 Jan 2016, 7:10 pm
this afternoon I took the tank off ready for spraying and found out why the filler cap doesn't close properly the front allen bolt of the the three long ones that screw into the tank has sheared off so stopping the cap going down far enough, so I keep spraying the bolt with wd and hope it soaks in, does anyone know where to get new filler allen bolts ?
Re: off with the tank
Post by sullivj on Thu 07 Jan 2016, 8:20 pm
@skyrider wrote:this afternoon I took the tank off ready for spraying and found out why the filler cap doesn't close properly the front allen bolt of the the three long ones that screw into the tank has sheared off so stopping the cap going down far enough, so I keep spraying the bolt with wd and hope it soaks in, does anyone know where to get new filler allen bolts ?
Jerryfudd might have some. I remember he changed his.
Post by geewhizz on Thu 07 Jan 2016, 8:21 pm
have you looked at pro-bolts ?
https://www.pro-bolt.com/aluminium-fuel-cap-kit-honda-7.html
Post by skyrider on Thu 07 Jan 2016, 8:28 pm
thanks guys just hope the old one will come out without shearing again
Post by jerryfudd on Thu 07 Jan 2016, 9:02 pm
yup, probolt - there are two Honda kits if memory serves so make sure you get the right one. just check how many long and short bolts come and compare that to the CB.
Post by skyrider on Thu 07 Jan 2016, 9:05 pm
thanks Dan there are three long and the rest are short on mine
    Current date/time is Mon 28 May 2018, 2:12 am
