Unrestricting CB500 from 35kW
Pugzilla
Post by Pugzilla on Mon 14 Dec 2015, 10:22 am
My restriction is up in a few months.
Will I notice much of an increase in power if I unrestrict it?
It's a theoretical increase of over 7 kW (~20%).
More top end power perhaps?
Re: Unrestricting CB500 from 35kW
Post by wornsprokets on Mon 14 Dec 2015, 10:33 am
Yeah u wil cb do easy 110mph it quick enough for 2 cylinder engine
Post by wornsprokets on Mon 14 Dec 2015, 1:54 pm
That power restrictions a joke. In uk u can do direct access when ur a certain age and get full power bike then. Irish goverments a joke. Theres not even bike m.o.t,   they dont give a shit about bikes ...  they love cyclists..  and they dont stop for traffic lights no vis no lights no wonder few been killed this year
Post by Jameshambleton on Mon 14 Dec 2015, 2:49 pm
I've had 100mph out of my 35KW cb500 on my dads private land of course. I would have gone for more but I ran out of road.
Post by skyrider on Mon 14 Dec 2015, 7:14 pm
strewth your dad must have a long drive affraid
Post by Jameshambleton on Mon 14 Dec 2015, 8:46 pm
"private land" "yes that's right officer" Twisted Evil
biglee
Post by biglee on Mon 14 Dec 2015, 9:15 pm
hi my pal dad is a caretaker for a private airfeild and when not in se my friend and i rn our bikes on it  speedo on my cbf 500 read 120 mph flat out  very concistant over 5 run s p and down the runway
Post by skyrider on Mon 14 Dec 2015, 9:24 pm
well that would be fast enough for me on mine I think Cool
Pugzilla
Post by Pugzilla on Tue 15 Dec 2015, 9:26 am
Don't care much about top speed.
Will i notice better acceleration in the powerband range of RPM?
Post by ashcroc on Tue 15 Dec 2015, 10:24 am
It depends to an extent how your bike's restricted .
If you've got carb inlet washers you should notice an improvement over the whole range as the bike will be running on the correct air/fuel mixture once removed (some washer restriction kits also changed the carb jets for bigger ones to compensate so they may need changing too).
If however you have a throttle lock fitted, removing it will give you the ability to accelerate harder but the bike will run exactly the same until you twist the grip past where the cutoff was.
Pugzilla
Post by Pugzilla on Tue 15 Dec 2015, 11:37 am
It only has restriction plates from Kickstart Engineering.
So I should notice an improvement across the rpm range?
Post by wornsprokets on Tue 15 Dec 2015, 1:33 pm
It be a different bike cheers
phorx999
Post by phorx999 on Mon 21 Dec 2015, 11:30 am
can i just point out that you have to do both mod 1 and 2 again before you can do that. that's what pisses me off about the new licences.
Don't mean to be a mood kill
Post by skyrider on Mon 21 Dec 2015, 7:48 pm
all these new tests are hard work, when I took mine the examiner sent you round the block and you could see him running from lamp post to lamp post with a clip board and you had to be careful not to run him over doing the emergency stop Laughing
Pugzilla
Post by Pugzilla on Tue 22 Dec 2015, 1:34 am
@phorx999 wrote:can i just point out that you have to do both mod 1 and 2 again before you can do that. that's what pisses me off about the new licences.
Not in Ireland
phorx999
Post by phorx999 on Tue 22 Dec 2015, 1:08 pm
Not in Ireland
affraid Gutted.
gotta do both to ditch the restriction in april
    Current date/time is Sun 18 Feb 2018, 8:21 pm
