Brake lever (Handle)
Post by Guest on Tue 08 Dec 2015, 12:14 pm
Bike dropped - brake handle bent... Mad  happens.
Looking into secondhand replacement parts, will any of these fit? Anyone?
Honda ST 1100 Pan European (2001)
Honda NT 650V (1998)
Honda VFR 750F (1994 - 1997)
Also, if I remember well there's been a topic or at least related discussion in a topic on the issue of adjustable handles for both brake and clutch handles... can't find it. Yet. Thanks in advance...
EDIT: post link found here: http://www.cb500club.net/t1021-adjustable-levers?highlight=adjustable+lever
Last edited by Werner Van der Straten on Tue 08 Dec 2015, 2:29 pm; edited 1 time in total
Re: Brake lever (Handle)
Post by Beresford on Tue 08 Dec 2015, 1:42 pm
They can be straightened easily enough using a bench vise, if you have access to one. In the past I've straightened levers using 3 large bolts or pieces of hardwood to press the lever back into line. This technique also works with alloy levers provided they aren't too far out of true.
The Honda brake lever, being flat steel, is also easy to grip in the vise and lever back into shape using a (largish) adjustable wrench.
Post by Beresford on Tue 08 Dec 2015, 1:45 pm
Sorry, just read your post again - you mean the lever on the handlebars, not the foot pedal. No
Post by Guest on Tue 08 Dec 2015, 4:49 pm
UPDATE: http://avdb-moto.fr/shop/en/levier-de-frein-flip-up/438-levier-de-frein-ajustable-repliable-kawasaki-ninja-250-300-08-14.html
Which means these will fit the CB500R 1994 as well: http://www.amazon.com/POWTEC-PTL-115-Adjustable-CBR500R-X-Black/dp/B00MCJZXF4/ref=sr_1_2?s=automotive&ie=UTF8&qid=1449591985&sr=1-2&keywords=adjustable+levers+CB500R
Am I right?
EDIT: But I think these will be fine and at a good price: http://shop.the2wheels.com/7-Clicks-GP-Levers-Adjustable-HONDA-LE7-HO.htm Important! These are for Nissin Master cylinder.
Celt500
Post by Celt500 on Fri 11 Dec 2015, 5:46 am
Maybe I'm being a bit dim here but how does an adjustable brake lever not reduce braking power?
Like if you have it set to the closest reach won't the lever hitting the bar reduce your ultimate braking force? Especially if you were coming down a mountain and get some brake fade for example?
Post by ashcroc on Fri 11 Dec 2015, 9:50 am
The trick is to have the lever adjusted inward enough to be comfortable for smaller hands while still far enough out not to hit the bar when fully depressed.
Post by skyrider on Fri 11 Dec 2015, 7:33 pm
would dog legs work
Llewelyn1965
Post by Llewelyn1965 on Fri 11 Dec 2015, 11:31 pm
I think M & P sell them for about a fiver.
dado_dassler
Post by dado_dassler on Tue 29 Dec 2015, 11:52 pm
has anyone fitted adjustable levers on the brembo model?
i would like to try out some if they can be installed without too much hassle.
Post by ashcroc on Wed 30 Dec 2015, 12:04 am
Iirc @jerryfudd found a pair that fit the Brembo mc..
dado_dassler
Post by dado_dassler on Wed 30 Dec 2015, 10:48 pm
@ashcroc wrote:Iirc @jerryfudd found a pair that fit the Brembo mc..
found it, thank you!
Post by Guest on Fri 08 Jan 2016, 1:04 pm
Eventually I got these and am very pleased with them:
1    | LE7_HO  | 7 Clicks GP Levers - Adjustable (HONDA)  | 12/09/2015    | RB926888764HK
                  Levers Set Honda Model: CB599 / CB600
                  HORNET 1998-2006 (F-18/H-626)
                  LE7 - Levers selection: Regular / Black
                  Adjuster Color: Black
    Current date/time is Sat 21 Apr 2018, 4:57 am
