Fuel line
cuddlydave38
Fuel line
Post by cuddlydave38 on Tue 10 Nov 2015, 5:10 pm
Hi silly question but does the fuel line from the fuel tank connect to the carbs from the top or from the bottom of the carbs.
ratatooie
Re: Fuel line
Post by ratatooie on Tue 10 Nov 2015, 5:25 pm
Unless I am mistaken, it connects to the middle of the (brown) pipe that links each of the float bowls of the carbs (behind the idle adjuster).
cuddlydave38
Re: Fuel line
Post by cuddlydave38 on Tue 10 Nov 2015, 5:28 pm
Does the brown pipe need to be either up or down for the fuel line to be connected or does it matter.
Re: Fuel line
Post by eternally_troubled on Wed 11 Nov 2015, 12:42 pm
@cuddlydave38 wrote:Does the brown pipe need to be either up or down for the fuel line to be connected or does it matter.
From memory I think it usually points downwards, however this shouldn't matter as it is all below the bottom of the tank, so getting fuel in (even if slightly uphill) shouldn't be a problem.
Re: Fuel line
    Current date/time is Sat 23 Jun 2018, 1:50 am
