spred a spring
biglee
spred a spring
Post by biglee on Thu 05 Nov 2015, 5:23 pm
hi all this might have been done before   so if u have a powerfull spring that needs stretching simply bend it and wedge 2p pieces into it when desired lengh fit and remove coins
Re: spred a spring
Post by jchesshyre on Thu 05 Nov 2015, 6:12 pm
E.g. side- and centre-stand springs - absolute b*stards.
Excellent tip!
Re: spred a spring
Post by Beresford on Thu 05 Nov 2015, 7:42 pm
@jchesshyre wrote:E.g. side- and centre-stand springs - absolute b*stards.
They're actually quite easy when you know how.
Wink
^smug git expression
Re: spred a spring
Post by skyrider on Thu 05 Nov 2015, 8:31 pm
come on spill the beans Smile
Re: spred a spring
Post by sullivj on Thu 05 Nov 2015, 8:34 pm
Great tip.
Re: spred a spring
Post by Beresford on Thu 05 Nov 2015, 9:17 pm
@skyrider wrote:come on spill the beans
OK then.
Make a loop of nylon cord a bout 9" or so long. Hook one end of the spring to the chassis point and the other into the nylon loop. Insert a big screwdriver or piece of wood (this is better to prevent scratching) through the loop and lever the spring into position using a wheel spoke or whatever is convenient as the fulcrum. Hook the spring over the stand lug and release the lever. The loop can then be jerked free.
Re: spred a spring
    Current date/time is Wed 21 Feb 2018, 11:13 am
