2 x Under trays - Both in good condition and one with a pair of mini indicators attached directly, rear lights included with both £15 each
1 x "S" model clocks - In good order but not tested with 29,000 miles on the odometer. Replaced facsia with my old one so LH edge has had repair of white plastex but doesn't affect use £60
2 x Handlebars - Both in fair condition £10
2 x Sidestands - Both cone with a set of springs and safety switches but they have not been tested for functionality £15 each
2 x sets of side grab rails - One pair has set of indicators attached and is in general good order, the other one is is badly rusted and is without indicators £15 and £5 per pair respectively
1 x set of "S" model yokes - They look in good order and come with both parts and handlebar clamps. Note that these will not suitable for regular unfaired CB500s. There are a set of open caged bearings but these will likely need replacing before use £30
2 x Pillion grab handles - One silver one black and both in need of a rubs down and respray in my opinion £10 each
2 x Seat catches - One has a key included £12 for one with key £8 for one without
1 x Ignition switch - No key included and the seat catch one doesn't fit £15
2 x Main stand - Each could do with a clean up and lick of paint, no springs included but each has a pivot pin that hasn't seized in £15 each
2 X LH switchgear - Not tested but externally in good condition £10 each
1 x "S"model front fairing bracket - Very rusted but looks straight and true with tabs intact £15
2 x pairs of rear shocks - Rusted all over and slight pitting visible on piston rod but no signs of leaking so might be serviceable with a bit of tlc. No brand visible and one pair has had a spray of black paint on one side only £15 per pair
2 x Horns - Tatty but solid £3 each
2 x Rear brake switches - £5 each
2 x Sprocket covers - £5
1 x Chain guard - £10
