No rear brakes
No rear brakes
Post by wornsprokets on Sat 26 Sep 2015, 9:24 pm
So went out for spin on cb , had great ride but no rear brakes Sad. Dont really use them unless in rain,. Anyway checked caliper hose brake pedal and ( put rear pads in  in march cleaned caliper and pins then)so i checked brake fluid  it was very dark colour, could swore i bled them in march also, must been just front i did Shocked. So bled them and back good again , doubt brake fluid change colour since march, whats shelf life of brake fluid?
Re: No rear brakes
Post by sullivj on Sat 26 Sep 2015, 9:33 pm
I would have thought bi-annual fluid changes would be fine. Thats what I do.
Maybe you forgot in March.
Re: No rear brakes
Post by teamster1975 on Sun 27 Sep 2015, 11:17 am
To be honest I change the fluid once in a blue moon, it won't stop the brakes working when the fluid gets old. Brake fluid is hygroscopic which means it absorbs moisture, it's still a liquid which is not compressible.
Just bleed it for starters, make sure you've got no weeps around the piston!
Re: No rear brakes
Post by Jameshambleton on Sun 27 Sep 2015, 11:59 am
Brakes fluid *should* be changed every two years.
Re: No rear brakes
Post by wornsprokets on Sun 27 Sep 2015, 12:51 pm
I had no leaks from caliper seals i could see , i didnt take off brake pads , there was next to no feel from brake pedal, it did bite but not enough to stop very strange.  Fluid was like used engine oil colour? Must been fluid
Re: No rear brakes
Post by Jameshambleton on Sun 27 Sep 2015, 3:36 pm
seems like you'd got a lot of water in it. Have the checked the resource cap?
Re: No rear brakes
Post by wornsprokets on Sun 27 Sep 2015, 5:23 pm
By resource cap you mean rear master cylinder cap and seal there fine.maybe its time for braided lines all round!
Re: No rear brakes
Post by Jameshambleton on Sun 27 Sep 2015, 7:19 pm
Yeah that's what I meant, I'm a little tired....
Re: No rear brakes
Post by wornsprokets on Sun 27 Sep 2015, 8:49 pm
Sleep
Thats allowed james
Re: No rear brakes
Post by jerryfudd on Mon 28 Sep 2015, 8:39 am
I was just watching a YouTube vid (good channel for picking up tips that can be applied to any bike) and he discusses the colour of brake fluid... maybe worth looking at?
https://www.youtube.com/watch?v=J5nuh39VAu8
Bit you'll probably be interested in is at 11mins and 15seconds.
(for those that don't want to watch it could be deterioration of the OE hose)
Re: No rear brakes
    Current date/time is Wed 23 May 2018, 11:53 am
