LED Indicators
Ayrton F
Ayrton F
LED Indicators
Post by Ayrton F on Wed 23 Sep 2015, 11:18 am
Hey guys!
I picked up a set of LED indicators last week for my CB500. I never realised I needed to pick up a new relay along with them as well. Is there a specific LED Relay that I have to get for my CB500?
The guy in the shop was saying getting the right relay can be very difficult because some may work with the bike but wont work with the indicators etc ... Any ideas ?
Re: LED Indicators
Post by jerryfudd on Wed 23 Sep 2015, 1:14 pm
just a universal 3 pin one will be fine I believe.
Ayrton F
Ayrton F
Re: LED Indicators
Post by Ayrton F on Wed 23 Sep 2015, 1:38 pm
http://www.ebay.ie/ulk/itm/251760268267
Hi Jerry,
Thanks for that. Would something like this be suitable ? I've found a few cheaper but your waiting weeks on those as opposed to days with the expensive ones.
Re: LED Indicators
Post by jerryfudd on Wed 23 Sep 2015, 1:45 pm
no, the 3pin connector (although you might find it only has two actual pins within the 3pin connector and an external earth) have to be in this horizontal configuration.
this is exactly what the one I had on my CBF600, briefly on the CB500 and now on my Street Triple looks like...
Just look up 'Honda 3 pin LED indicator relay' on eBay.
Re: LED Indicators
Post by ashcroc on Wed 23 Sep 2015, 5:54 pm
This came up recently in another thread. There's a link in my reply quoted below that'll work.
@ashcroc wrote:You'll either need an electronic relay (this one will cope with both led & bulbs if only changing one end) to correct the flash rate or load resistors to fool your current mechanical relay into thinking you still have bulbs fitted.
If you have a naked cb & go the relay route you'll probably also need to do a 'diode mod' to the shared idiot light to stop all 4 indicators flashing at the same time.
I went the resistor route last time I put led winkers on a bike as it was quicker (& they came with them) but I always intended changing to the tidier resistor/diode method as resistors can get hot especially if you fit the larger ones that only require one per side.
This time I'll be changing the relay at first fit.
Ayrton F
Ayrton F
Re: LED Indicators
Post by Ayrton F on Thu 24 Sep 2015, 4:57 pm
Thanks for that Ash,
I will probably use a relay as Id like to keep it as tidy as possible. I have a 99 CB500S so I'm not sure if I will require the diode mod ? To be honest the most I've done with electrics to date involved taking off the headlight housing. Nothing major, like messing around with the loom, yet.
Re: LED Indicators
Post by ashcroc on Thu 24 Sep 2015, 5:59 pm
No need for a diode mod on the s models as they have independent left & right inicator idiot lights.
Re: LED Indicators
    Current date/time is Sun 24 Mar 2019, 7:39 pm
