Hard suspension
Hard suspension Empty Hard suspension
Post by muttley1 on Sun 13 Sep 2015, 8:29 pm
Hi all,
I've hagons shocks fitted to my bike and they seem to be getting more solid, they are 10k old I'd estimate. Its now a hard ol' ride especially on backroads but the bike corners great on smoother roads and tracks well.
Anyone else noticed their hagons going solid and is there a fix? I fancy changing the springs to something softer, bit of spannering fun on a sidestand only bike thrown in.
cheers
Celt500
Celt500
Hard suspension Empty Re: Hard suspension
Post by Celt500 on Mon 14 Sep 2015, 1:05 am
Funny you should mention that, I was going to ask if there's any maintenance you're supposed to do with them?
 Mine are about 5k miles in and I'm starting to find things a bit bumpy.
Not sure if I've imagined it's worse than before? Also had a few little back-end slips recently but that might be coincidence.
As you say though, corners great all the same.
Post by jchesshyre on Wed 16 Sep 2015, 11:15 am
I take it they're on the lowest preload setting?
Post by muttley1 on Wed 16 Sep 2015, 2:23 pm
Yep, the things have 3 preloads, I use the lowest. Only affects ride height.
m1
Brillpaul
Brillpaul
Post by Brillpaul on Sat 16 Jun 2018, 4:41 pm
Mine has hagons on about 4K and failed MOT today as they were too solid. Front failed as well. Am I going to be bankrupt?
Post by eternally_troubled on Sat 16 Jun 2018, 8:17 pm
Hmm that's interesting... suggests that all the Hagons seem to get solid. I wander if they 'seize up'? Seems unlikely. Mine are also pretty hard though.
If I were in your position I would buy some of the (recommended by the forum) TEC shocks - https://shop.tecbikeparts.com/products/cb500-shocks
skyerae
skyerae
Post by skyerae on Fri 29 Jun 2018, 6:17 am
Brillpaul, I suggest you overhaul your front shocks - I did mine and it was an easy enough job (although I did overhaul hydraulic rams for a short while in my varied career) It depends on what the front failed on, is it a standard setup on the front?
Brillpaul
Brillpaul
Post by Brillpaul on Sat 14 Jul 2018, 11:04 pm
Thanks, my rear hagons were seized so replaced with new hagons. I was lucky to get a good set of front forks on Enay and a local guy who sets up suspension for racing did all the work so she runs like a new bike......I may keep her until I'm 70 next year!!!! Yehaaaaa
    Current date/time is Wed 21 Aug 2019, 6:43 pm
