front brake reservoir diaphragm plate
dado_dassler
Solved front brake reservoir diaphragm plate
Post by dado_dassler on Sun 13 Sep 2015, 3:38 pm
i'm looking for the diaphragm plate located between the front brake reservoir cover and the diaphragm, too late i found out that mine is missing and there doesn't seem to be any part no. for it.
there was fluid slowly weeping down the reservoir cover and onto the left side of the bracket holding the reservoir, there's a tiny patch about 3 mm wide of blistered paint layer on the bar alongside the bracket, the fluid has moved underneath the bars and onto the top yoke and further down to the chunk of frame beneath where beautiful black paint the size of a big coin has become blistered and started peeling off.
i have washed the affected parts to prevent further damage to the paintwork.
does anyone have a spare diaphragm plate lying about that they're willing to sell me?
Solved Re: front brake reservoir diaphragm plate
Post by eternally_troubled on Sun 13 Sep 2015, 5:46 pm
Good luck in finding one of them - it could be quite difficult!
If you can find a thin bit of stiff plastic and cut it to the correct shape it might be worth trying to 'make' a new one and give it a try.
Post by stormbringer on Mon 14 Sep 2015, 6:49 am
@dado_dassler wrote:i'm looking for the diaphragm plate located between the front brake reservoir cover and the diaphragm
Hmmm. Try calling Probike at 8622 6296. Bent's little shop has been nominated 'Sparepart supplier of the year' in Denmark and has most things on stock. OE Honda parts, that is. He's a firm believer in quality stuff, meaning there's none of the THansen (Halfrauds) bargains to be had.
Post by Jameshambleton on Mon 14 Sep 2015, 4:19 pm
I've also got the same problem only that it ran all the way down my mudguard and it's bubbled all of the paint. I'm just going to do a master cylinder/reservoir swap, easier and most likely cheaper than buying parts.
Alvi
Post by Alvi on Mon 14 Sep 2015, 9:13 pm
Whenever I've had to rebuilt any part of the brake system, I've replaced the fluid with silicone brake fluid - no more bubbling paint if you spill it or get a leak anywhere.
davecb5002
Laser Shark
Laser Shark
Post by davecb5002 on Tue 15 Sep 2015, 8:28 pm
Is it a Nissin or Brembo master cylinder ??May be able to help with the Brembo one .Dave Very Happy Very Happy
dado_dassler
Post by dado_dassler on Wed 16 Sep 2015, 4:48 pm
@eternally_troubled wrote:If you can find a thin bit of stiff plastic and cut it to the correct shape it might be worth trying to 'make' a new one and give it a try.
that will be my last resort, guess i will have to mimic the original one and drill a breathing hole through it too?
@stormbringer wrote:Try calling Probike at 8622 6296. Bent's little shop has been nominated 'Sparepart supplier of the year' in Denmark and has most things on stock.
thank you for the link and phone number, i will call him tomorrow.
@davecb5002 wrote:Is it a Nissin or Brembo master cylinder ??May be able to help with the Brembo one .Dave
dave, it's a brembo master cylinder, bike is from 2000.
@Alvi wrote:Whenever I've had to rebuilt any part of the brake system, I've replaced the fluid with silicone brake fluid - no more bubbling paint if you spill it or get a leak anywhere.
i never knew such brake fluid existed - any disadvantages?
i have been to four motorcycle shops so far with no luck, one of them told me he would check their supplier and call me tomorrow.
Flyingbrick
Post by Flyingbrick on Wed 16 Sep 2015, 5:16 pm
The disadvantage is that a silicon fluid (DOT 5.0) is not suitable for the CB (gaskets may be harmed) and that it may not be mixed with any other fluid. Furthermore, it is not temperature stable, so if the fluid heats up, the pressure point at the lever will travel.
For this reasons, I would strongly recommend the usage of DOT 4 or 5.1 fluid instead of 5.
Regarding the plate: this part is not available as a single item, you have to buy the whole expensive calliper assy to get it. Therefore, you should buy a used part instead.
Post by ashcroc on Wed 16 Sep 2015, 6:31 pm
@Flyingbrick wrote:<<>>Regarding the plate: this part is not available as a single item, you have to buy the whole expensive calliper assy to get it. Therefore, you should buy a used part instead.
It's the master cylinder rubber gasket he's after not anything in the caliper. They're still showing available at Lings so I'd have though a main dealer could also source them.
Flyingbrick
Post by Flyingbrick on Wed 16 Sep 2015, 6:48 pm
Sorry, I'm not sure about the proper translation.
I was talking about part 9 at http://www.lingshondaparts.com/hpl/images_large/13MY5WEA/imge/F__0400.jpg
Unfortunately, that's the PC26 parts list.
This is the similar picture for the PC32 with Brembo brake:
http://www.lingshondaparts.com/hpl/images_large/13MY5WEA/imge/F__0401.jpg
The part under the top cover and above the (rubber) diaphragm is not sold separately and I guess this is the desired part, isn't it?
jim157
Post by jim157 on Wed 16 Sep 2015, 6:49 pm
Ashcroc, it's plastic plate that sits in between the diaphragm and the master cylinder lid.  It keeps the diaphragm in place and stops it from contorting.
It's definitely a part that could be 3D printed.  I'll ask my mate who does it as a business if it would be viable (in terms of cost and brake fluid resistance).
Post by badseeds on Wed 16 Sep 2015, 8:24 pm
dado_dassler, can you send a PM to davecb5002 as he says he's got one.
dado_dassler
Post by dado_dassler on Wed 16 Sep 2015, 8:59 pm
@badseeds wrote:dado_dassler, can you send a PM to davecb5002 as he says he's got one.
ye, i just did, thank you.
    Current date/time is Tue 17 Jul 2018, 7:56 pm
