Experiences with the clutch
Post by Guest on Thu 20 Aug 2015, 7:00 pm
For a while changing gear from first to second would rather often end up in neutral followed by that  engine roar at 8k revs... tongue  you know the thing.
However just recently found out that if I put a little pressure (up) when in first then upon pulling in the clutch the gears almost instantly and without any clonking (as it used to do) noise goes into second... what a joy.
My question is as to whether this behaviour is a sign of something wearing or 'normalish'?
Re: Experiences with the clutch
Post by jchesshyre on Thu 20 Aug 2015, 9:18 pm
1. You need to be firm with the gear lever.
2. Make sure the clutch cable has 10-20mm play measured at the tip of the lever.
Post by eternally_troubled on Mon 24 Aug 2015, 8:35 am
This sounds quite normal.
On my bike (and probably other peoples) you have to be very firm and positive to ensure you don't get stuck between 1st and 2nd gear.  I've got used to it (it is a flaw of the gearbox - it shouldn't be like that, but a lot of bikes are similar) and it still occasionaly happens to me when I'm not paying sufficient attention.
Post by Guest on Mon 24 Aug 2015, 9:13 am
Great! Thanks for the feedback.
Post by jchesshyre on Mon 24 Aug 2015, 9:17 am
One other thing: the quality and condition of the oil makes a difference to the slickness of gear changes.
Ayrton F
Post by Ayrton F on Mon 24 Aug 2015, 11:02 am
I used to have problems as well with the "fasle neutral" .. just be firm with your gear changes and it shouldnt happen! Nothing worse than hearing the revs soar like that!
    Current date/time is Sat 21 Apr 2018, 10:46 am
