My Track bike project
My Track bike project Empty My Track bike project
Post by ANDYC on Sat 15 Aug 2015, 3:55 pm
A lot of people have told me to put up a thread on my track bike project, so here it is Very Happy
A few pictures to show how far I have got so far.
My Track bike project 00311
My Track bike project 00511
My Track bike project 00412
My Track bike project 00114
So far it is a CB500 s frame modified to take a CBR400RR (NC29) swingarm and suspension. The rear wheel is a CBR900RR fireblade one (£1.20 on fleabay), running a 180/55/17 tyre. I'm using a cb500 sprocket carrier machined down to align the chain run, with a CBF500 output shaft to space out the front sprocket.
The front end is from a CBR600RR4 with a front wheel from a SP1 and a 120/60/17 tyre. The brake discs will be Brembo 310mm when funds become available. The clip-ons are only on for ease of moving it about, it will have a set of renthal bars on it once I have the top yoke conversion done. The lower yoke is from a CBR900rr (98 model) the pinch bolts on the RR4 fouled the radiator at full lock.
The observant ones will notice that the rear upper engine mount has been removed to allow the monoshock to be aligned properly.
I have made one to be fitted just under the shock mount, but ran out of argon, so welding that in will have to wait. Neutral
The engine cases/head have just been vapour blasted and will be painted once I have finished using it to position everything correctly. They are currently empty apart from the gearbox output shaft. (I saw no need for lifting a complete engine about unless necessary)
I shall endeavor to post pictures and any progress as they occur Very Happy
My Track bike project Empty Re: My Track bike project
Post by Jameshambleton on Sat 15 Aug 2015, 4:40 pm
Looking forward to reading through this thread as your project progresses!  Smile
Post by wornsprokets on Sat 15 Aug 2015, 7:15 pm
Wow good work, just shows what u can do if you put your mind to it. Lot of work just to get it to this stage  keep up good work☺
Post by ashcroc on Sat 15 Aug 2015, 11:15 pm
Looking good so far. You planning on keeping the tail section or converting to something more strealined with a single seat?
Post by ANDYC on Sun 16 Aug 2015, 10:54 am
I'm still not sure about the bodywork, although it will be a single seat unit. Probably a one piece race unit.
My preference is to keep the standard style of the 500 'S'.
That's why I went to the trouble of keeping the same style wheels rather than take the easy route and use the 600rr 3 spoke wheels. I did try them but they just didn't seem right for this bike. I guess it's down to personal taste.
My Track bike project 01112
Post by ANDYC on Sun 16 Aug 2015, 3:38 pm
Now sporting a radiator originally meant to grace a CBR400rr (NC29)
As I won't be running a cooling fan, thermostat and all the hoses that go with them a larger radiator would be required.
The CB500 does run quite cool unless you're stuck in traffic.
Although how a tuned engine will behave is yet to be discovered. Very Happy
My Track bike project 001_212
My Track bike project 004_212
My Track bike project 00611
My Track bike project 00911
scottrichardwalker
scottrichardwalker
Post by scottrichardwalker on Sun 16 Aug 2015, 7:11 pm
Hi Andy
Really interesting stuff. I look forward to reading the updates to this thread as and when they arrive.
All the best with the future works.
Scott
Post by jerryfudd on Mon 17 Aug 2015, 7:57 am
looking really good....... is this destined for the Thundersport? I thought they were pretty strict about mods?
scottrichardwalker
scottrichardwalker
Post by scottrichardwalker on Mon 17 Aug 2015, 8:02 am
Thundersport are indeed very prescriptive about the modifications you can make whilst still allowing you to compete.
In fact, you can't even use a K&N air filter as this is a "Performance upgrade", so unfortunately, I shouldn't think we have much chance of seeing this machine in that particular series anytime soon.
Post by ANDYC on Mon 17 Aug 2015, 7:53 pm
This is destined for trackdays. I'm building it how I want it and not down to regulations.
And for no other reason than because I can Very Happy
Even my work bike (CB500S) is too modified to fit into a race class.
I'm also a bit too old to start being a conformist now. tongue  Laughing
Post by ANDYC on Sun 25 Oct 2015, 12:02 pm
At last a little progress has been made.
The rear upper engine mount has now been welded in, as has the lower suspension mount.
I'm pleased to announce that the bike can now stand on it's own wheels.
This is quite a milestone as I can now determine the ride height and position the other things such as seat, bars, footpegs etc.
My Track bike project 001_312
My Track bike project 005_310
My Track bike project 003_310
My Track bike project 002_210
Post by ANDYC on Wed 28 Oct 2015, 3:41 pm
Finally got around to getting a Dyno run done for my work bike.
As this will be used as a 'mule' for testing my project engine I needed a base line to work with.
I didn't think it was too bad for a courier bike that's done well over 150k, it also runs a higher gearing (15/39 and a 160/60 rear tyre)
The larger capacity alternator didn't seem to cause any great losses either.
My Track bike project 001_410
Post by ANDYC on Sun 15 Nov 2015, 11:52 am
I got around to fitting the 4 degree ignition advancer to see if it made any difference.
And the answer is yes it certainly did Very Happy
There seems to be a much crisper throttle response and more bottom and midrange power.
Of course all this was judged by a test ride, and a spirited one at that! So until it goes back on the dyno next month I can't say for sure.
Tuning the CB500 doesn't list high on the tuning companies 'must do' list so I have to do a lot of research to find parts. This gem came from a VTR1000.
My Track bike project 001_510
My Track bike project 002_310
As far as mods go, this had to be the easiest to do. The hardest part was cleaning the gasket faces to fit the new cover gasket.
Mad_Taffy_500
Mad_Taffy_500
Post by Mad_Taffy_500 on Sun 15 Nov 2015, 12:37 pm
Nice little  mod to know about keep it up
rwhitton
rwhitton
Post by rwhitton on Tue 17 Nov 2015, 3:47 pm
Really interested in the ignition mod as I race but not with thundersport. Any more details appreciated.
Post by Jameshambleton on Mon 07 Dec 2015, 8:04 pm
Any more updates on this Andy?
Post by ANDYC on Mon 07 Dec 2015, 9:04 pm
I have been busy rebuilding my cylinder head, lapping in the standard valves and helicoiling the exhaust stud threads.
This head had 0.5mm skimmed from the face and was gasflowed. I'll be fitting it to my work bike in the next few weeks and get it run on the dyno to see what gains it gives.
I measured the bores to see if I can run 73mm forged pistons or if I would need to bore it out to 74mm.
I was very impressed to find that there was no wear at all on the bores so I can keep the standard size pistons, although they will be forged and higher compression.
Sorted out what code bearings I need for the crankshaft main bearings, having the crankcases vapour blasted almost removed the bearing size markings Rolling Eyes I do check them all using plastiguage anyway, but it's nice to have a starting point.
Just to confirm that I can multitask when I feel like it, I have decided to change the chain and sprockets to a 520 set-up. This reduces weight, friction and energy required to turn it. Which means that less power is wasted in between the engine and the back wheel.
Hopefully I should have a dyno run to show gains from the cylinder head, ignition advancer and the 520 chain in the next month or so.
Although Xmas is likely to reduce my available garage time I'm sure. Not to mention the annual dent in the finances. I'm dropping hints about the pistons that I want, wouldn't it be nice to find a pair under the tree Very Happy
ratatooie
ratatooie
Post by ratatooie on Tue 08 Dec 2015, 10:38 am
Loving reading about this project!
Post by ANDYC on Sun 13 Dec 2015, 8:14 pm
Spent this afternoon sorting out the shims and exhaust studs on the cylinder head. The stud threads I helicoiled, and used high tensile m6 x 35mm grub screws rather than the crap studs that are originally fitted.
All the shims are done and the head is ready to be fitted to my test mule, all I need now is time to do it.
Post by ANDYC on Tue 05 Jan 2016, 8:36 pm
I have finally got around to doing the 520 chain conversion Very Happy
It feels so much better, although this could just be down to the new chain and sprockets.
Losing 1.5 kilos from the chain and sprockets can't be a bad thing whichever way you look at it!
Hopefully it will show up on the next dyno run as a reduction in power lost before it reaches the rear wheel.
I was a bit hesitant about the strength issue, however my friend uses one on both his BMW S1000 and a gsxr750 with no problems so I feel safe.
Post by ANDYC on Sat 27 Feb 2016, 11:34 am
A bit of an update, if only to show that I haven't given up Very Happy
The ignition advancer, although the bike felt much livelier on the road with a much crisper throttle response there was no significant gain showing on a dyno run. This could be due to a number of reasons, all of which I will explain.
My best guess would be the slipping clutch, which is self explanatory really. This is going to be replaced with an EBC kevlar one soon.
I took apart a spare airbox as I thought that it could be restrictive, and my findings were...........!
Whoever designs airboxes to enhance Honda's breathing ability must have been on holiday when this was designed! I was designed to fit in the frame and that's it.
The air intake has an area of 18.4cm/2  (40x46mm)
This is reduced to 16.62cm/2 by the 46mm diameter tube that the air filter sits on.
2x 34mm carbs have an area of 18.16cm/2 (not accounting for butterfly and spindles)
Whilst this looks just do-able in figures, lets take into account that this is trying to suck the air in through a 90 degree bend in the tube and the resistance of the air filter. Already I reckon that we are down to at least 70% efficiency, Then take into account that the initial intake is pointing backwards so that whatever speed you are doing at a given time must create a partial vacuum.
It seems reminiscent of running in a gas mask, anyone with military experience will not have forgotten that episode I'm sure.
Those who have not just imagine trying to breathe with a pillow over your face.
I have now set myself the task of building a more suitable airbox for my needs. The confined space between the carbs and the fuel tank mean that suitable individual pod filters are not an option.
Due to funds or more importantly the lack of funds, the fitting of FCR39 carbs has been shelved until I win the lottery.
Plan B is fitting a pair of 38mm CVK's from an early Fireblade. This in itself is no mean feat, but it can and will be done.
I have dismantled a set and sorted the spacing using a donor pair of CB500 carbs. There are a few as of yet unfinished minor issues such as the idle adjusting screw, the Fireblade one was just not accomadating. The inlet rubbers need to be bored out to 46mm to suit, The set of carbs I had were missing the alloy bellmouths so I need to source a pair of those. The spacer bars can be finished to the correct length once I'm confident that I won't need to strip them apart anymore. Here's a couple of pictures to show the differences.
My Track bike project 006_210
My Track bike project 007_210
My Track bike project 008_210
I also decided to adapt a standard cam chain tensioner and convert it to a manual one, It has done 1600 miles so far and no problems at all, I'll explain all after a 10k trial period.
Post by ANDYC on Sun 05 Jun 2016, 3:58 pm
It seems like an age since I last had any time to press on with the project, but a little progress has been made.
I have now managed to successfully bore out the new inlet rubbers to suit the 38mm fireblade carbs.
This done I now know that the spacing is correct and I can tidy up the studs holding them together as well as other things like getting them ultrasonic cleaned and set up the jetting.
I will struggle with an airbox as there's very little clearance with the suspension mount, so I'll have to rethink that aspect of it.
My Track bike project 00111
My Track bike project 00310
My Track bike project 00210
Post by ANDYC on Sat 11 Jun 2016, 1:12 pm
The air filters arrived, so I got to checking them for clearance with a fuel tank.
And found that there isn't any  Sad so I'll have to modify the tank to make some room.
This will probably mean disposing of the fuel tap too. Which isn't as bad as it sounds because this isn't a road bike and I can just use a 'dry break' self sealing hose connector.
My Track bike project 00110
It's a pity I can't use a high flow airbox that I made, but the upper suspension mount would mean that I would have to go back to a twin shock set-up. I haven't completely eliminated that idea yet, but will see how this route evolves first.
Post by wornsprokets on Sat 11 Jun 2016, 1:31 pm
U done amazing work on your race bike  andy  well done Very Happy
Post by ANDYC on Sat 11 Jun 2016, 4:24 pm
  • Maurice Ogier's Montjuic
    Maurice Ogier poses with the unique Ogier-Laverda in front of the Daytona bankings, after Alan Cathcart had scored a flag-to-flag victory on it in the Lightweight BoTT race in Cycle Week 1984.
    My Track bike project Ogier
    The smallest capacity bike ever to win a Daytona BoTT race, the little Laverda was able to punch well above it's weight, thanks to Ogier's careful development of the 500cc DOHC, 8 valve 180-degree Montjuic engine.
    So successful was it, that the AMA insisted on him stripping it after the Daytona victory, because they couldn't believe a bike with a street based engine that small could go so fast - no less than 148mph through the Daytona traps from just 579cc!!
    Ogier had bored the engine to 77.8 x 61mm using special Mahle pistons, in which form it delivered 74bhp at the rear wheel, at 9800rpm, running on twin 38mm Dell'Ortos. Modified valve timing using stock Montjuic cam profiles narrowed the power some, making the standard 6-speed gearbox an advantage. The low dry weight of 290lb (132kg) was obtained with the stock Montjuic roadster chassis, but with the fuel tank moved under the seat and fuel supplied by an exhaust driven vacuum pump. This speeded up the handling in slow turns without sacrificing stability on the banking - enabling Cathcart to become the first British rider ever to win a Cycle Week race of any kind, as well as register the first overseas victory in a Daytona BoTT race.
I just thought I would show everyone where my inspiration came from. If it could be done 32 years ago! Very Happy
    Current date/time is Mon 22 Jul 2019, 9:23 pm
