Cush drive rubbers
Cush drive rubbers
Post by Guest on Fri 10 Jul 2015, 3:48 pm
Anyone knows if these will be the same for the CB500X and CB500R ?
Found some next to new at half new price and am planning for the winter overhaul of sprockets, chain, cush drive (sprocket hub) and drum brake.
Re: Cush drive rubbers
Post by jchesshyre on Sun 12 Jul 2015, 8:07 am
If you mean a CB500-X from 1999 then yes; if you mean a CB500X from 2013 onwards then no.
Post by Guest on Sun 12 Jul 2015, 12:52 pm
Indeed, after some searching I found the following latest models that do:
2003 CB750
1987 CMX450C
1986 VFR750F and VFR500F
1985 VF500
1984 VF1000
and others such as:
CBR900RR, XBR500, CB350, CB450, XBR500, ... but in general HONDA seems to have stopped using them from somewhere early 2000's.
Thanks again
Post by stormbringer on Mon 13 Jul 2015, 6:01 am
Werner Van der Straten wrote:... but in general HONDA seems to have stopped using them from somewhere early 2000's.
Hmmm...
I'm thinking 'why that?' here.
I mean - motorbikes haven't changed that much over the years. Why all the sudden remove a drivetrain component whose job it is to take up shock? I have a hard time believing that Honda's engineers 20 years on in a sudden flash of revelation discover that they've been wrong all this time.
It's much more plausible that pressure from the bean counters has led to - ahem - cost optimizations...
Post by Guest on Mon 13 Jul 2015, 8:24 am
@Stormbringer
Sorry my bad English here at work. I meant to say that somewhere after 2000 no use is made in new bikes for that particular cush drive rubber number 41241MA6000.
Post by stormbringer on Mon 13 Jul 2015, 5:50 pm
Werner Van der Straten wrote:Sorry my bad English here at work.
Same thing goes for me. It all makes sense now...
    Current date/time is Sat 21 Apr 2018, 10:41 am
