Clutch removal
Clutch removal
Post by badseeds on Thu 25 Jun 2015, 11:48 pm
My clutch has started slipping in 5th, a sure-sign it's dying. I have a low-mileage clutch in a spare engine, that's not in a frame. What's the best way to go about removing it? I have a VFR800 clutch holding tool, I've no idea it it'll fit, but there's nowt else.
Re: Clutch removal
Post by jerryfudd on Fri 26 Jun 2015, 4:25 pm
out of curiosity what are the signs...... varying bursts of power?
Re: Clutch removal
Post by badseeds on Fri 26 Jun 2015, 4:30 pm
The revs increase and the tacho spins round, but no extra forward thrust. I had the same symptoms on a TZR125, XJ900 and VFR800 - all had worn friction plates.
Re: Clutch removal
Post by jerryfudd on Fri 26 Jun 2015, 4:33 pm
so rpm dial goes up but no increase on the mph?
i've never had a clutch go on my so always good to be able to spot the warning signs
Re: Clutch removal
Post by badseeds on Fri 26 Jun 2015, 4:39 pm
When clutches are dying they'll slip at speed - gunning mine in 5th at around 8k rpm makes it happen. It's fine for normal day-day riding, but chasing sportsbikes on the IoM has made my clutch protest.
Re: Clutch removal
Post by jerryfudd on Fri 26 Jun 2015, 4:45 pm
lol hmmmmm that'd do it Smile
Re: Clutch removal
Post by ANDYC on Fri 26 Jun 2015, 5:57 pm
If you're just going to change the plates then you only have to remove 4 x M6 bolts and the springs.
If you want to change the whole unit then I recommend something like this, using an old sprocket.
Re: Clutch removal
Post by badseeds on Fri 26 Jun 2015, 10:32 pm
That's what I was hoping to hear, Andy. Cheers!
alvamiga
Re: Clutch removal
Post by alvamiga on Sat 27 Jun 2015, 9:19 pm
Slipping sounds the same as when my clutch started to majorly fail on my 125... 100 miles from home! Wink
Re: Clutch removal
Post by Tricky. on Sun 28 Jun 2015, 9:53 pm
the easiest way to remove the nut that holds the clutch together is a air impact gun, the sort that you use for undoing car wheel nuts/bolts.
Re: Clutch removal
    Current date/time is Sun 18 Feb 2018, 5:06 am
