tec shock suspension settings
Post by wornsprokets on Sun 07 Jun 2015, 5:26 pm
So i put new set of tect shocks on bike, bit of ball ache as i had to remove the exhaust to get lower shock bolt out and the exhaust is original and never removed before , it was fun and games it eventually came off after lot of swearing:)  anyway what settings are u using. I am on setting from set up by tec seems to be ok, these are bog standard ones  what settings do use guys use
Re: tec shock suspension settings
Post by eternally_troubled on Mon 08 Jun 2015, 1:16 pm
I don't know about the TEC shock settings, but on the standard exhaust you'll need a new graphite gasket/seal collar to make it seal when you put it back on. They can be a bit of a bastard to remove as you found out.
Plus, I moved you topic to the 'workshop' section...
Post by wornsprokets on Mon 08 Jun 2015, 1:29 pm
Yes i have removed  that gasket as it broke up never seen anything like that before and ive removed gud few exhausts on bikes and cars, i used a paste on exhaust we see if it holds wasnt blowing this morning anyway Smile       thanks anyway eternally troubled for advice
Post by Guest on Mon 08 Jun 2015, 3:32 pm
Is there a easy way to tell if shocks are worn out?
Post by wornsprokets on Mon 08 Jun 2015, 8:19 pm
one of mine was leaking,  there some difference with new ones, generally if u push down on back of the bike it should come back into position in controlled way if its really bouncy its bad sign , but swing arm bearings could be in bad too they need to be checked  if theres movement in swing arm side ways.
    Current date/time is Sun 18 Feb 2018, 4:48 am
