Weird battery failure
HomeBrew
Post by HomeBrew on Sat 30 May 2015, 7:46 pm
I rode the bike home no problems, when I went to leave after 1.5 hours the bike was completely dead, checked the voltage it was 6 volts, changed it for a spare I had, rode back to where i'm staying and now the voltage is 10.4 on the old battery. Has it broken inside do you think?
Re: Weird battery failure
Post by Tricky. on Sat 30 May 2015, 8:59 pm
reg/rec knackered.
Post by Tricky. on Sat 30 May 2015, 9:01 pm
whats the voltage to the battery when its running?
HomeBrew
Post by HomeBrew on Sat 30 May 2015, 9:19 pm
14.7 v at idle, drops to 14.3 when revving. Lights off in neutral.
Post by Tricky. on Sat 30 May 2015, 10:42 pm
must have a short somewhere then.
Post by Tricky. on Sat 30 May 2015, 10:44 pm
check voltage when just switched off, then check every 15mins.
Post by Tricky. on Sat 30 May 2015, 10:45 pm
do the above test on both batteries and compare results.
Post by wornsprokets on Sat 30 May 2015, 10:58 pm
Agree with tricky honda regulators are piece of s--t , they dont always totally blow my experience of them they partically work and that can confuse u, the one on my fireblade it  only acted up when lights are on and bike cut out at traffic lights and battery was flat and it started with push. It also damaged battery damaged a cell. And i coped this  put multimeter to battery disconnected from bike and reading kept dropping  did not stabilise .dead cell in batt, and it was a bosch and fairly new. Cb has done same also after 60 mile journey with headlight on batt was dead but didnt damage batt on this bike. Honda 1990s gremlin problem and cheap ebay ones dont last that long either so  i heard
    Current date/time is Mon 23 Apr 2018, 11:43 pm
