Oil Change
Jim164
Oil Change
Post by Jim164 on Thu 21 May 2015, 9:34 am
Hi There,
I am looking to do my first oil change on my CB this weekend , I have got the new oil filter to fit and will get some 10w40 oil to replace the existing Oil. My question is how much oil does the CB take , i have tried looking in the Hayes Manual but can't find it nor have I been able to find any threads on here.  If someone can atleast give me a ballpark figure as I also need to know how large a container to put under the bike.
Any advise / opinions on this would be appreciated.
Jamie
Re: Oil Change
Post by teamster1975 on Thu 21 May 2015, 10:37 am
Hello mate
Oil change: 2.9 litres
Oil & filter: 3.1 litres
It's in Haynes in the specifications section of chapter 1.
Jim164
Re: Oil Change
Post by Jim164 on Thu 21 May 2015, 10:44 am
Cheers for that ,
JUst looked again in the manual and now I can see (DOH).
Thanks again
Re: Oil Change
Post by teamster1975 on Thu 21 May 2015, 11:07 am
No worries, it's not obvious when you're looking for it!
Re: Oil Change
Post by ashcroc on Thu 21 May 2015, 11:19 am
The haynes lists fluid volumes,bolt torques etc. At the start of each chapter.
Re: Oil Change
Post by teamster1975 on Thu 21 May 2015, 11:23 am
It'll always be the book of lies though Razz
Re: Oil Change
Post by Beresford on Thu 21 May 2015, 11:21 pm
Wierd this. At my last oil and filter change I very carefully emptied the engine, including spinning it on the starter to remove anything in the oil galleries. It then took a full 4 litres to fill it to the mark.
Re: Oil Change
Post by badseeds on Thu 21 May 2015, 11:33 pm
@Beresford wrote:Wierd this. At my last oil and filter change I very carefully emptied the engine, including spinning it on the starter to remove anything in the oil galleries. It then took a full 4 litres to fill it to the mark.
Maybe your measuring jug is dyslexic.
Re: Oil Change
Post by Beresford on Thu 21 May 2015, 11:44 pm
Well, you gotta believe those sealed 4 litre containers aren't lying. Shocked
Re: Oil Change
Post by teamster1975 on Sat 23 May 2015, 12:06 pm
Sure you didn't leave out the sump plug? Razz
Re: Oil Change
Post by Beresford on Sat 23 May 2015, 12:59 pm
@teamster1975 wrote:Sure you didn't leave out the sump plug? Razz
Hardeharharhar Evil or Very Mad
However I had ensured that there was no remaining old oil in the engine by making certain that the oil galleries and pump body were thoroughly drained.
Not forgetting that the dipstick is not to be screwed in when checking oli level.
Re: Oil Change
Post by teamster1975 on Sat 23 May 2015, 1:42 pm
I guess it's possible, Haynes reckon 3.5 litres in a dry engine after a rebuild.
Re: Oil Change
Post by Beresford on Sat 23 May 2015, 1:55 pm
Truly a mystery  study
stefanos
oil fylter
Post by stefanos on Wed 08 Jul 2015, 3:19 pm
hi guys what oil fylter do we use at cb and how often do we have to change it....
steady Eddy
Re: Oil Change
Post by steady Eddy on Wed 08 Jul 2015, 5:32 pm
@stefanos wrote:hi guys what oil fylter do we use at cb and how often do we have to change it....
Change your oil filter every oil change with any compatible oil filter.
Last one i used was hi-flo from Wemoto and i change my oil every 4-5k.
Re: Oil Change
Post by badseeds on Wed 08 Jul 2015, 5:43 pm
I change my oil every 4,000 miles. Honda specify 8,000 miles, but that seems way too high...... I've used HifloFiltro, Meiwa, Filtrex and Genuine Honda oil filters and never had an issue. Any half-decent semi-synthetic oil will do. I usually just buy whatever the best deal is on ebay, for instance. Change the filter at every oil change.
Re: Oil Change
    Current date/time is Tue 23 Jan 2018, 7:50 pm
