Back left indicator
Stu9
Back left indicator
Post by Stu9 on Fri 15 May 2015, 2:49 pm
Unless they're both the same
For a 96 cb5...I can't get the nut off on mine, I want to put the rack on I got with the bike but one rusted nuts stopping it...I've tried grinding with the dremel but to tight and snapped a few discs
So I'll need to cut it from the stalk so if anyone's got a back left (or if it doesn't matter what side) gimme a shout
Re: Back left indicator
Post by ashcroc on Fri 15 May 2015, 8:40 pm
I'm sure I've got at least one knocking around you can have for postage. Can you remind me of the wire colours please, I don't want to send a front left by accident.
Stu9
Post by Stu9 on Fri 15 May 2015, 8:55 pm
Thanks ash...I'll try and check shortly, how much will post be
Post by ashcroc on Fri 15 May 2015, 9:10 pm
Shouldn't think it'll be much. I'll check tomorrow once I've  fished the flasher out & got an idea of the package size. Should be small enough to go through RM post.
Stu9
Post by Stu9 on Fri 15 May 2015, 9:15 pm
Stu9
Post by Stu9 on Sat 16 May 2015, 11:39 am
According to the beano (Haynes) it's orange or red and green wires
Post by ashcroc on Wed 20 May 2015, 3:46 pm
Sorry, after hunting I can only find the later ones I got in a job lot. Guess I must've chucked the ones I pulled off my T when I went over to led.
    Current date/time is Wed 23 May 2018, 4:12 pm
