clutch cable routing
Scorgie88
Post by Scorgie88 on Tue 12 May 2015, 7:13 pm
http://rs1074.pbsrc.com/albums/w408/scorgie88/Mobile%20Uploads/DSC_0393_zpscf0sbwfp.jpg~320x480?t=1431367642
Good Evening
I've replaced my clutch cable this evening and was a bit concerned about the routing. Hopefully the pictures worked, if it hasn't I'll try again when I can get to a computer. I was wondering if its too close to the radiato?
Thanks!
Scorgie88
Re: clutch cable routing
Post by Scorgie88 on Wed 13 May 2015, 8:29 am
Post by eternally_troubled on Wed 13 May 2015, 12:33 pm
I think that is probably fine, but I would have to go and look at my bike (not with me right now) to see if it is the same as I've got.
Sometimes there is more than one way that works...
Scorgie88
Post by Scorgie88 on Wed 13 May 2015, 12:53 pm
Yeah seems to be working ok, great actually, always is freshly lubed up!
I'm just worried that on anything longer than my commute it's gonna get too hot. Time will tell I suppose, I'll have to carry a spare.
If you wouldn't mind could you post a pic of how yours is when you get a chance?
Thanks for answering all of my newbie questions eternally_troubled. Reckon I'd be cycling everywhere by now if it wasn't for you!
Post by ceejay on Wed 13 May 2015, 3:18 pm
Mine is routed through the inside of that part of the frame after going through the holder loop FWIW but I'd imagine yours will be fine if you haven't had problems already.
In fact you might even avoid the problem of the cable rubbing where it leaves the housing at the engine end. That is what caused my last one to go and looks like better routing could prevent it but I haven't played with it so don't know.
Post by teamster1975 on Wed 13 May 2015, 4:35 pm
Here's mine:
Post by eternally_troubled on Thu 14 May 2015, 12:46 pm
Ah ha!  It looks like teamster's one goes a bit more 'left' than yours, away from the radiator.
I'll have to have a look at mine for comparison...
EDIT: I have looked at mine. It looks like teamster's one.
Mine goes through that guide ring, up the frame tube and then bends towards the left of the bike (towards the clutch) and goes in-between the fork legs behind or underneath the headlight.
Might be worth checking that your one doesn't go around the RH fork leg... that might explain why it has ended up in the wrong place.
Post by ashcroc on Thu 14 May 2015, 6:42 pm
Had a look at mine & it goes inside the frame at the strut by the top rad hose.
Scorgie88
Post by Scorgie88 on Fri 15 May 2015, 1:32 pm
By inside the frame do you mean up here?
Post by ceejay on Fri 15 May 2015, 2:36 pm
Not through that hole in the frame where it joins but to the left:
Post by teamster1975 on Fri 15 May 2015, 4:52 pm
Yes it goes up under the tank and across the head stock. Sorry the photo's a bit pants, the sun actually came out!
Post by ashcroc on Sat 16 May 2015, 12:10 pm
Here's an eBay pic which shows the cable routing quite well.
Scorgie88
Post by Scorgie88 on Tue 19 May 2015, 7:52 am
Thanks everyone, got mine routed the same as most of yours.
Solved!
    Current date/time is Thu 26 Apr 2018, 2:23 pm
