buying standard exhaust clamp
dado_dassler
Post by dado_dassler on Fri 08 May 2015, 1:53 pm
hello folks! Very Happy
i have recently bought a standard exhaust to experiment a little and i'm looking for one of these no. 4 on this sketch.
anyone selling or do know of a cheap solution online?
i do have other types of clamps that might fit to it but i want something less bulky if possible.
Re: buying standard exhaust clamp
Post by eternally_troubled on Mon 11 May 2015, 1:25 pm
Ah. Yes, that is the standard exhaust clamp.
I haven't tried this, but I suspect you could replace it with two or three large jubilee (hose) clips, like these
http://www.hcl-clamping.co.uk/Jubilee-Clip-Worm-Drive-Hose-Clamp-P69
you can probably get them in the correct diameter if you go to the right shop.
dado_dassler
Post by dado_dassler on Mon 11 May 2015, 2:37 pm
thank you for the input.
i have found some different ones that i will fit on to begin with, and if none of them fit properly then i will try with the hose clips.
the left and top ones seem very powerful, the right one is 1st on the list.
Post by eternally_troubled on Wed 13 May 2015, 12:36 pm
The one on the right hand side of your picture looks a bit like some that are on my old Ducati (from 1974!)
Anyway, as long as it clamps well it doesn't really matter what you use...
    Current date/time is Fri 20 Jul 2018, 12:00 am
