2 questions
Stu9
2 questions
Post by Stu9 on Thu 07 May 2015, 6:29 pm
What's this bit called.....i'd call it the seat latch....the metal rod thingy that's under it to hold it up
The front engine mount bolt...it goes right through doesn't it....it went to fit crash bars that I got with the bike but the bolts seized...I guess soaking in wd is the only way or can I heat it with the touch bit dodgy being ally though
Re: 2 questions
Post by teamster1975 on Thu 07 May 2015, 6:51 pm
Was there supposed to be a photo with that first question?
The front engine bolt is a bastard. Several days soaking with Plusgas (much better at penetrating than WD), and if that won't shift it lots of heat.
Stu9
Re: 2 questions
Post by Stu9 on Thu 07 May 2015, 6:56 pm
Thanks for a quick answer
No I was just asking...it's just a metal rod but don't know it's right name
So these front bolts are a c+?t I'd need to get plusgas as I've never used it, so I can heat it will it not discolour the ally
Re: 2 questions
Post by ashcroc on Thu 07 May 2015, 7:04 pm
You have a seat prop? (the latch is the bit that locks the seat) As far as I'm aware there was never one either supplied with the bike or offered as an optional extra though as the recess for one is included on the seatpan I've often considered fabricating one.  Any chance of a pic?
As for the bolt, people have had to resort to drilling them out in the past.  There's at least one thread on getting them out.
alvamiga
Re: 2 questions
Post by alvamiga on Sun 10 May 2015, 11:28 pm
Is there a proper seat prop? I have a bit of wood stored under there! Very Happy
Stu9
Re: 2 questions
Post by Stu9 on Sun 10 May 2015, 11:34 pm
It's a nut...as I said, it's the back indicator and the hollow shaft it's on to...drilling, I'd like to see that being done
Re: 2 questions
Post by wornsprokets on Sun 10 May 2015, 11:48 pm
Never seen plus gas here(ireland) yes have been looking at getting that engine front mounting bolt out. What were they thinking designing engine bolt like that the dumbasses. Mines seized in solid too be weary breaking engine mountings as it be easy to do. Think heat be a bit too close for my liking. Thinking off leaving it as it is.no seat prop on mine
Re: 2 questions
Post by muttley1 on Mon 11 May 2015, 10:53 am
No seatprop on any cb5 i've owned. I keep a length of batten cut to hold the seat up when needed. Its surprisingly useful.
Re: 2 questions
Post by eternally_troubled on Mon 11 May 2015, 1:13 pm
I don't think anyone has an original seat prop - there wasn't one AFAIK. I think there is a space for one in the plastic moulding of the seat pan.
Yes, the front engine bolt is a bad design/wrong place/wrong materials. When you finally get it out and replace it with a new one make sure you give it a good coating of copper slip (will resist engine temperatures) at all points it meets something else. It is also worth undoing it every year or two, taking it out and repeating the process as a preventative measure.
Re: 2 questions
Post by teamster1975 on Mon 11 May 2015, 1:47 pm
@eternally_troubled wrote:When you finally get it out and replace it with a new one make sure you give it a good coating of copper slip (will resist engine temperatures) at all points it meets something else.  It is also worth undoing it every year or two, taking it out and repeating the process as a preventative measure.
+1 to all of that.
Re: 2 questions
    Current date/time is Sat 24 Feb 2018, 2:15 pm
