top tip check your coolant
ar1
Post by ar1 on Sun 12 Apr 2015, 6:29 pm
Hi guys i have just been checking the condition of my coolant as i do not know how old it is, using a meter set the dc  volt range to 0.00 put the red lead to the engine and the black into the overflow tank the reading should be 0.10 to 0.3 0,if its higher u need to change if you leave it it will get worse and it will eat your gaskets and radiator u have been warned old anti freeze will make your rad leak and blow head gaskets, regards J
    Current date/time is Tue 24 Apr 2018, 12:09 am
