fork oil ?
sinclairmic
fork oil ?
Post by sinclairmic on Tue 10 Feb 2015, 3:15 pm
Im changing the fork seals on my cb tomorrow. what is the best type of fork oil for smooth handling to replace my current oil? also what volume will fill both? thanks
Re: fork oil ?
Post by jerryfudd on Tue 10 Feb 2015, 3:21 pm
Think I used 10wt but as far as volume goes your better off working to the air gap rather than a set amount.
Re: fork oil ?
Post by geewhizz on Tue 10 Feb 2015, 7:30 pm
i went for 20w and 120mm air gap, firmed the front up nicely. 15w wasn't firm enough and I've read that 25w is overkill.
Re: fork oil ?
Post by badseeds on Tue 10 Feb 2015, 10:28 pm
@geewhizz wrote:i went for 20w and 120mm air gap....
That's what I did. Worked a treat.
Re: fork oil ?
Post by ashcroc on Thu 12 Feb 2015, 4:03 am
Air gap will depend on the age of your bike.  Honda changed the size of the spacer & oil level a few times over the years.
Re: fork oil ?
Post by stormbringer on Thu 12 Feb 2015, 7:11 pm
Haynes? I did mine according to said reference and am happy as a lark...
Re: fork oil ?
Post by muttley1 on Thu 12 Feb 2015, 8:02 pm
seconded, Haynes gives different air gaps depending on year.
As to oil, standard is 10w. 15 or 20 will firm up the front a fair bit. However, you can't adjust the spring tension on the rear shocks, just the ride height so getting a bike that rides well on the roads you ride is down to personal preference. Be prepared to have a couple of goes to get something you are happy with. If the front of the bike feels high (as it will with firmer oil) you could drop the forks through the yokes a few mm.
Btw, hagon springs, which do firm up the front a fair bit, use 7.5w oil.
atb
sinclairmic
Re: fork oil ?
Post by sinclairmic on Thu 12 Feb 2015, 8:26 pm
So i changed the oil and dodgy seal on the right fork of my bike. myself and my uncle who is very mechanically minded took 2 hours getting the old seal out. it was seized in place in the end we had to get a dremel down the gap and cut the metal ring in the seal to pull it out! I fitted the new seal, some oil leaked out at first as it settled but now it is gone.
Re: fork oil ?
Post by eternally_troubled on Fri 13 Feb 2015, 1:35 pm
@sinclairmic wrote:So i changed the oil and dodgy seal on the right fork of my bike. myself and my uncle who is very mechanically minded took 2 hours getting the old seal out. it was seized in place in the end we had to get a dremel down the gap and cut the metal ring in the seal to pull it out! I fitted the new seal, some oil leaked out at first as it settled but now it is gone.
FYI - it might be better to (at least) change the fork oil in both legs to make sure the damping is the same on both sides...
The fork seals can be a bit of a pain to get out (as you found), especially if they have been in for a good while.
sinclairmic
Re: fork oil ?
Post by sinclairmic on Fri 13 Feb 2015, 5:07 pm
Just open the oil cap on the bottom of the fork. Empty it then refill with the same oil as the other side?
Re: fork oil ?
Post by eternally_troubled on Sun 15 Feb 2015, 12:14 pm
Not all the CB500 forks have oil drain bolts... only the earlier ones!
I think most of them have the casting but don't have the hole tapped, so you could probably make some if you wanted.
HomeBrew
Re: fork oil ?
Post by HomeBrew on Sat 21 Feb 2015, 1:28 pm
You can take off the cap, out with the spacer, put a piece of sellotape over to stop the spring coming out, hold it upside down and pump it into a container, mark the level, empty and refill with fresh oil to the same level and pour it in.
I think you are meant to change fork oil every 5,000 miles or so.. all that scraping of the spring makes metal filings degrades the oil and stops the damping working. Fresh 10wt made a nice improvement for me.
Ayep
Re: fork oil ?
Post by Ayep on Sat 28 Feb 2015, 12:04 pm
I've had different experiences with 15W.
On one of my bikes, it stiffened everything up considerably. Better feel in the bends, but a little bit stiff for longer roadtrips.
On the other bike, same year, but different 15W brand, it didn't actually change a lot, felt like the older 10W stuff! Bizarre.
In the future, I'll stick to the branded stuff, and probably mix 2/3 15W and 1/3W, should be a good compromise. I'm surprised people use 20W, unless the bikes are for track use?
peatrich
Re: fork oil ?
Post by peatrich on Sat 28 Feb 2015, 12:47 pm
Is there any danger of 20W bursting the seal?
Re: fork oil ?
Post by geewhizz on Sat 28 Feb 2015, 2:51 pm
nae i've had 20w in for a while now and its fine, as noted the track/race guys seem to favour 20w and there bike probably get punished a bit more than ours. fair enough we have to deal with potholes but i wouldn't worry.
Celt500
Re: fork oil ?
Post by Celt500 on Sat 28 Feb 2015, 8:04 pm
@peatrich wrote:Is there any danger of 20W bursting the seal?
No, the only danger is the suspension will be too stiff for the road and the front tyre could skip over rough surfaces and loose grip or lock up easier under braking.
The handling on mine improved a lot just with new seals and oil, everything set up totally standard with 10W.
Re: fork oil ?
Post by eternally_troubled on Sun 01 Mar 2015, 3:58 pm
Fork oil does vary quite a bit - one manufacturers 10 may be like another manufacturers 15 etc.
Re: fork oil ?
    Current date/time is Sat 21 Apr 2018, 4:36 am
