relay
parkwayvtec_19
relay
Post by parkwayvtec_19 on Fri 16 Jan 2015, 11:41 am
Hi everyone..!!
First of all ive just recently registered in this club. Im from spain and im the owner of a cb500 2001.ill need a bit of help from you guys.I do not know if this topic is all ready discussed but i just want to know where i can find ( located on the motorcycle )the flash relay on my cb500. i need to change it bcoz i change the flasher and the lights are switching too fast..thanks
Regardss..
Last edited by parkwayvtec_19 on Fri 16 Jan 2015, 11:43 am; edited 1 time in total
Re: relay
Post by jerryfudd on Fri 16 Jan 2015, 11:42 am
are you using LED indicators? if so I don't think the problem is CB500 specific you just need some LED indicator resistors - readily available and universal on eBay....
parkwayvtec_19
Re: relay
Post by parkwayvtec_19 on Fri 16 Jan 2015, 11:45 am
they are not leds they are bulbs actually they are from in a suzuki gladius flasher
parkwayvtec_19
Re: relay
Post by parkwayvtec_19 on Fri 16 Jan 2015, 11:56 am
i really want to know where is located the flash relay in my cb500 so i can change it
Re: relay
Post by jerryfudd on Fri 16 Jan 2015, 11:57 am
right hand side, at the back under the fairing just in front of the ECU
parkwayvtec_19
Re: relay
Post by parkwayvtec_19 on Fri 16 Jan 2015, 12:16 pm
thanks you so much for help..!!!
Re: relay
    Current date/time is Fri 23 Feb 2018, 6:23 am
