alternator / generator / rectifier problems
legge248
Post by legge248 on Mon 22 Dec 2014, 6:41 pm
hi all!!! im having a problem with my alternator on my 1999 cb500s, out of the three yellow wires two are getting warm when connected to the rectifier, does this point to a short from alternator to rectifier or is it more likely a stator fault , the only reason i ask is i dont want to be breaking gaskets if it is the rectifier , thanks in advance aaron
Stooby2
Re: alternator / generator / rectifier problems
Post by Stooby2 on Mon 22 Dec 2014, 7:01 pm
Can you give a bit more info please. Ignition on or off, engine running or not? Is there any charging still? When you say warm, too hot to touch or just warm?
Cheers.
legge248
Post by legge248 on Mon 22 Dec 2014, 7:17 pm
engine running, no charging (thats how i found the problem) and they seem to get hotter as the engine is running i turn off to avoid melting the insulation,  it seems like its only heating up when connected to the rectifier but i might be mistaken as i cant remember if i checked when unplugged lol
Post by teamster1975 on Mon 22 Dec 2014, 8:14 pm
Here's a good read for starters, keep us posted!
Post by Guest on Mon 22 Dec 2014, 8:34 pm
Top of my head impression is that only two out of three coils are supplying all the current, hence hotter wiring due to increased voltage drop as a result of higher current... guessing
Stooby2
Post by Stooby2 on Tue 23 Dec 2014, 7:14 pm
My guess is your rectifier is screwed and leaking to earth somewhere.
legge248
Post by legge248 on Tue 23 Dec 2014, 8:20 pm
I have replaced the rectifier and that has solved the problem , thanks for the help guys!!
Post by eternally_troubled on Wed 24 Dec 2014, 2:29 pm
Glad to hear you fixed it. It is usually the rectifier/regulator that is broken....
    Current date/time is Tue 24 Apr 2018, 12:06 am
