Rear Wheel Bearing Spacer
Post by jerryfudd on Thu 18 Dec 2014, 1:33 pm
Any one got or know where I can get the bearing spacer tube that goes inside the rear wheel?
COLLAR, RR. WHEEL DISTANCE - 42620-MY5-730
I've got one on order with my local dealer but they seem to have some supply issues and although I've been assured its coming - its coming from Japan and the current eta is April 2015?!
Odd part I know but at the moment its the only thing stopping the rebuild commencing - below is the reason why Shocked
I know its probably not beyond a clean up but id much rather a new one or at least a better'er one Very Happy
Re: Rear Wheel Bearing Spacer
Post by sullivj on Thu 18 Dec 2014, 5:32 pm
Dan, have you tried David Silver or Lings?
They might have one on the shelf?
Post by eternally_troubled on Thu 18 Dec 2014, 8:08 pm
Pfffft, that just needs a quick scrub and a coat of WD40 Smile
What do you mean you're not going to re-use those bearings.... ho ho ho
I can't help with where to get one from (other than the suggestions above). If honda can't get one then I suspect you could get one made out of a suitable bit of round section steel bar with the middle drilled out (assuming you can find somone with a biiig pillar drill).
Tried ebay or a local breakers? They might have one inside a CB500 wheel. You could buy the whole thing (for the right price) and sell the wheel bit on ebay.
Post by jerryfudd on Fri 19 Dec 2014, 11:50 am
DS came back with June/July next year as did Lings........ looks like I might be calling the powder coaters again!
Stooby2
Post by Stooby2 on Sat 20 Dec 2014, 12:04 pm
Jerry if you want to send it to me I'll give it the once over in my shot blasting cabinet. It'll bring it up nice and clean.
Post by jerryfudd on Tue 23 Dec 2014, 9:27 pm
    Current date/time is Wed 23 May 2018, 4:12 pm
