Coolant
igloocommando
Coolant
Post by igloocommando on Thu 11 Dec 2014, 5:45 pm
SO, I recently bought a 1998 500SW, in a decent(?) condition. BUT, on close inspection found that a new radiator was needed. Picked 1 up cheap enough from ebay but when I came to drain the cooling system got about a tablespoon of water from it. My question is, do I need to look deeper into the problem, or has the previous owner just run it dry?
Re: Coolant
Post by sullivj on Thu 11 Dec 2014, 6:29 pm
Where were you draining the coolant from?
igloocommando
Re: Coolant
Post by igloocommando on Thu 11 Dec 2014, 6:32 pm
Draining it from the water pump drain plug. Radiator cap removed, along with top and bottom hose.
Re: Coolant
Post by sullivj on Thu 11 Dec 2014, 6:44 pm
I take it there's no water in the oil? If not, refil it and check for leaks. It may have come out of the old radiator.
igloocommando
Re: Coolant
Post by igloocommando on Thu 11 Dec 2014, 7:09 pm
The old radiator didn't appear to have a leak, just very flat fins, and can't see any signs of water(foaming ) in the oil, so I reckon it's  just a case of flushing out, fitting new radiator and seeing.
Re: Coolant
Post by Beresford on Thu 11 Dec 2014, 7:49 pm
The flat fins syndrome is common - not just on cb500s. If the rad has no leaks the core can be brought back into serviceable condition by the careful - and labour intensive - use of fine nosed pliers to tease out and straighten the cooling fins. When you do this carefully and then give it a coat of satin black aerosol, the rad can look and perform just like new.
Re: Coolant
Post by sullivj on Thu 11 Dec 2014, 8:44 pm
Make sure the fan is working properly too.
igloocommando
Re: Coolant
Post by igloocommando on Thu 11 Dec 2014, 8:49 pm
Good point, I've gone through all  the normal tests - checked the fuse, put a fly lead between the fan switch lead and the frame, and the fan runs. The only thing I need to do now is mke sure the fan switch is working
Re: Coolant
Post by stormbringer on Fri 12 Dec 2014, 6:31 am
@igloocommando wrote:...when I came to drain the cooling system got about a tablespoon of water from it.
There's no harm done in filling up with water, give it a 30-second test run and then drain again. Personally, I wouldn't feel safe until I've seen water spurt some 40 cm out from the drain hole and collected - well, how much was it - 3 litres or so? - in a pan.
Then refill with the correct 50/50 mix of antifreeze/water.
"Perfect Preparation Prevents Poor Performance" as Guy Martin puts it...
Re: Coolant
Post by badseeds on Fri 12 Dec 2014, 3:48 pm
@stormbringer wrote:"Perfect Preparation Prevents Poor Performance" as Guy Martin puts it...
Perfect planning and preparation prevents piss-poor performance.
What's your address, Martin? I need to send that t-shirt.
Re: Coolant
Post by Beresford on Fri 12 Dec 2014, 7:25 pm
P......P.....P....P.....P......P.....P.....Possibly drunken
Re: Coolant
Post by stormbringer on Fri 12 Dec 2014, 8:04 pm
@badseeds wrote:What's your address, Martin?
PM...
igloocommando
Re: Coolant
Post by igloocommando on Sat 13 Dec 2014, 8:49 pm
Thanks for all the advice guys. I fitted the new radiator, filled it with 50/50 mix, it took about 2 litres, and was full to the top of the filler neck. Ran it for a good 10 to 15 minutes and all seems ok, no leeks and the level was still to the top of the filler. Top and bottom hose both getting hot so the coolant is travelling around the engine. Topped up the expansion tank and ran it again, still all seems ok. Temp gauge is registering, rather slowly, so I think the previous owner must have been a bit negligent in checking water levels. Everything else seems ok, no water in the oil etc, so we'll see. Still in the garage being tarted up so maiden voyage is still a bit away.
Re: Coolant
Post by sullivj on Sun 14 Dec 2014, 8:29 am
Glad you're all sorted. The temp gauges do take quite some time to register and normally mine would be about 20 mins on tick over before the fan cuts in.
igloocommando
Re: Coolant
Post by igloocommando on Sun 14 Dec 2014, 1:05 pm
Thanks for the tip, thought it didn't move very much - will keep my eye on it during the first ride, hopefully not to far off.
Re: Coolant
Post by eternally_troubled on Mon 15 Dec 2014, 12:40 pm
@igloocommando wrote:Thanks for the tip, thought it didn't move very much - will keep my eye on it during the first ride, hopefully not to far off.
That's not surprising: these bikes don't tend to run very hot. The fan on mine only comes on after standing idling for a while after a ride on a really hot day (like one or two days a year in the UK).
Basil Moss
Re: Coolant
Post by Basil Moss on Thu 18 Dec 2014, 5:45 pm
Blimey... So how far did you ride it with no coolant?
igloocommando
Re: Coolant
Post by igloocommando on Sun 11 Jan 2015, 6:35 pm
Didn't ride it without coolant, got it off ebay and put it on trailer. Only found the lack of coolant when it was on the lift in the garage.
Re: Coolant
    Current date/time is Sun 18 Feb 2018, 8:21 pm
