Repack Honda exhaust?
Celt500
Post by Celt500 on Wed 10 Dec 2014, 11:30 pm
Has anyone managed to repack the standard Honda silencer, or know if it's possible or how you would take it apart?
Re: Repack Honda exhaust?
Post by stormbringer on Thu 11 Dec 2014, 10:01 am
@Celt500 wrote:... repack the standard Honda silencer...
No idea. It seems this is a single-use component. Mine's from 2001 and makes the bike near-silent. Why would you want to repack it? Hoping to go all-stealth?
Post by eternally_troubled on Thu 11 Dec 2014, 12:54 pm
If you wanted to repack it I suspect you would need to (carefully) grind one or both ends off by grinding along the welds, repack (unpack ?!) and then weld it up again.
It probably wouldn't be too bad if you have some skills with welding; I don't have any skills so haven't tried it.
Post by jerryfudd on Thu 11 Dec 2014, 1:01 pm
for the stock look (at one point) I was looking at this which seemed pretty smart...
http://www.wemoto.com/bikes/honda/cb_500_y_2/00-02/picture/marving_original_style_silencer_-_black/
can always remove the manufacturer plaque.
Celt500
Post by Celt500 on Thu 11 Dec 2014, 1:58 pm
Well, people talk about the stock exhaust being too quiet, mine isn't.
And also it sounds a bit... I don't know, just slightly blatty (I don't think that's a word). I can't find any holes or leaks so I was thinking maybe the packing has burnt out a bit over the years.
Don't want to go totally stealth but don't always want to announce to the surrounding countryside that I'm going for it down the straights!
Having said that I'd stick a Fuel can it if I had the money but I need a front tyre and a few other bits.
Post by jerryfudd on Thu 11 Dec 2014, 2:03 pm
In that case I'd save yourself the work and just source a 2nd hand stock one..... they can't be too hard to find or expensive at the rate people are removing them?
Celt500
Post by Celt500 on Thu 11 Dec 2014, 2:44 pm
Fair point...  Smile
Post by stormbringer on Fri 12 Dec 2014, 6:19 am
@jerryfudd wrote:In that case I'd save yourself the work and just source a 2nd hand stock one..... they can't be too hard to find or expensive at the rate people are removing them?
Mine's definitely not for sale. I've put on a Fuel can - and I looove it! - but being a "UK road legal" thing it's actually not legal to use here. I'm an Outlaw!
So, should I ever decide to pass on the bike, the OE can will be needed for MoT (In Denmark there's no yearly MoT, only when trading bikes is MoT relevant. Authorities trust people to take care of themselves on this particular point). Also, should I decide to go abroad, the OE can is needed too. Going abroad may very well happen soon; I've got my eye set on southern England and Wales...
Post by eternally_troubled on Fri 12 Dec 2014, 12:16 pm
@stormbringer wrote: Also, should I decide to go abroad, the OE can is needed too. Going abroad may very well happen soon; I've got my eye set on southern England and Wales...
The only thing you might want to bring to the UK would be the baffle for your fuel can - you won't have any problems with the fuel can here.
I don't know what you might need to escape Denmark...
    Current date/time is Tue 24 Apr 2018, 12:05 am
