Fuel Exhaust, Baffle, Link Pipe & Clip - SOLD!
Post by jerryfudd on Thu 20 Nov 2014, 3:59 pm
As the title says I've got one of these for sale for the CB500 - the link pipe was attached with quite a bit of firegum or equivalent so as yet I haven't been able to separate the two by hand but then haven't really tried either.
There is also a dent on the hidden side of the can.
I'm thinking £50 + postage.....
Re: Fuel Exhaust, Baffle, Link Pipe & Clip - SOLD!
Post by eternally_troubled on Fri 21 Nov 2014, 1:39 pm
Jerryfudd, you have a PM...
Post by ashcroc on Sat 22 Nov 2014, 11:44 am
If he don't take it I'll buy it back!
BTW, it's grey silicon sealant on the joints so should come apart quite easily.
Post by eternally_troubled on Sat 22 Nov 2014, 12:54 pm
Too late, I've already bought it!
As I was saying to jerryfud, my current exhaust is held together by:
* epoxy putty (milliput to be exact)
* giant hose clips
* thin sheet metal
* VHT paint
As you might imagine the hose clips are strapping the sheet metal over the holes that are plugged with epoxy putty, the VHT paint is badly applied over the top of everything.
Post by jerryfudd on Sat 22 Nov 2014, 5:10 pm
Lol sounds very...... functional Smile
As the man says sold now.
Couldn't split the link pipe so wrapped all as one - atleast it will be air tight!
Post by ashcroc on Sun 23 Nov 2014, 1:44 pm
No worries I'll just get a new one sans battle scars Wink
Think I may have been a bit over zealous with the sealant but it was a long day sorting out the broken hanger between night shifts & I didn't want a blow.
Post by jerryfudd on Sun 23 Nov 2014, 2:03 pm
It's certainly on there! after nearly pulling my arm out trying to separate the two and of the opinion it's new owner would be putting it back in the same place I decided to leave it be Smile
New Beowulf one turned up yesterday Razz
Post by eternally_troubled on Sun 23 Nov 2014, 3:02 pm
@jerryfudd wrote:... of the opinion it's new owner would be putting it back in the same place I decided to leave it be :)
Ding! Correct! :)
Post by ashcroc on Sun 23 Nov 2014, 4:55 pm
@jerryfudd wrote:It's certainly on there! after nearly pulling my arm out trying to separate the two and of the opinion it's new owner would be putting it back in the same place I decided to leave it be Smile
Hehe that Loctite is decent stuff. I'm sure it'd be easier to pull apart if the link pipe was still clamped to the bike.
Out of interest,  which Beowulf can did you go for & does the link pipe have a stop for the centre stand? I assume you remembered to keep the rubber bung the stand rests on Wink
Post by jerryfudd on Sun 23 Nov 2014, 5:17 pm
S/S Oval 380mm - same as on my CBF.
Link pipe pic for the CB500 below straight out the box....
    Current date/time is Sat 23 Feb 2019, 2:54 am
