headstock bearings
headstock bearings
Post by jerryfudd on Thu 06 Nov 2014, 10:58 pm
I've managed to remove the old races from the frame which was a bit of a sod even with the sealey removal tool and am doing a little tidying with wet and dry where it nipped the frame - question is how do I make sure the two recessed surfaces in the frame are perfectly flat and parallel to each other? does it even matter down to the mm?
cbeebies
Re: headstock bearings
Post by cbeebies on Fri 07 Nov 2014, 1:28 am
You wouldnt be able to take much off with wet n dry. Personally I just give them a scrape with a screw driver to remove the dirt and rust (if any). If the opposing faces arent true then youll get uneven wear on the new bearings, and possibly may get a tight/loose spot in the turning.
Tip: when fitting the new races, stick them in the freezer for 30 minutes prior to fitting and heat the headstock up with a heat gun (obviously not hot enough to damage the paint) but even a little heat really helps open up the hole!
Post by jerryfudd on Fri 07 Nov 2014, 8:11 am
I'm sure, its probably more a want to/curiosity than I 'need to'... think my OCD is just freaking out a little Smile
    Current date/time is Sat 21 Apr 2018, 10:52 am
