Pannier rack wanted
Solved Pannier rack wanted
Post by Jameshambleton on Tue 04 Nov 2014, 5:39 pm
I'm looking for a pannier rack for my CB500 1997 and would prefer to buy one that is a "tubular frame" type rather than the givi n150 type.
Does anyone have one for sale or know where I could buy one.
Many thanks.
davecb5002
Laser Shark
Laser Shark
Solved Re: Pannier rack wanted
Post by davecb5002 on Thu 13 Nov 2014, 9:24 pm
Hi- Is it a pannier rack or just a top box rack you require. I have a tubular Rentec top box rack if that is what you want. Regards Dave
Post by Jameshambleton on Fri 14 Nov 2014, 9:44 am
@davecb5002 wrote:Hi- Is it a pannier rack or just a top box rack you require. I have a tubular Rentec top box rack if that is what you want. Regards Dave
Pannier rack is what I need really but thank you for the offer.
Wildwards
Post by Wildwards on Fri 14 Nov 2014, 5:06 pm
I'm after a rear rack. Is a topbox rack different from the usual rentec rear rack?
Stooby2
Post by Stooby2 on Fri 14 Nov 2014, 9:26 pm
The Renntec ones generally use the grab rail mounting points and I'm pretty sure you lose the grab rail. You can just about get a Givi plate onto them but you need to make a bracket up.
Givi racks replace the side rails (where the indicators mount to) and mean you can fit a wide range of Givi plates and boxes. The indicators mount through the Gibi bars and you keep the grab rail.
stevew
Post by stevew on Fri 14 Nov 2014, 9:47 pm
PM sent
Wildwards
Post by Wildwards on Fri 14 Nov 2014, 11:20 pm
@Stooby2 wrote:The Renntec ones generally use the grab rail mounting points and I'm pretty sure you lose the grab rail. You can just about get a Givi plate onto them but you need to make a bracket up.
Thanks Stooby, that's very helpful.
Post by ashcroc on Sat 15 Nov 2014, 1:19 am
I'm 100% sure you lose the grab rail when fitting a renntec rack.
Alot of topbox manufacturers incuding givi, kappa etc make universal plates that'll have the clamps to go on. You may wish to cut off the grab handle bit of the renntec rack so you can mount the plate further forward.
Another option is a krauser rack & side arms that fits their k4 & k5 boxes though they're certainly not a cheap way to go.
Post by eternally_troubled on Sat 15 Nov 2014, 1:33 pm
You loose the standard grab rail (the silver thing on the top) when you mount a renntec rack - the rack has a bit of a grab rail built in (see here) but I'm not sure how good it is (never used one).
When you install the Givi monorack monunting rails you loose the two grab handles (the black ones that that the indicators usually mount on) as the rails mount insead of the handles.
So either way you loose something.
Wildwards
Post by Wildwards on Sat 15 Nov 2014, 4:26 pm
Thanks for all the info guys. Blimey! They are quite pricey those Renntec racks. Last time I bought a new one it was only about 30 quid.........mind you that was for a CX back in 1981. Ha!
So I'm assuming then that the one Dave is talking about back in the second post will be a tubular Rentec rear rack with a fitting for a top box? If it is Dave, I'm interested in the rack.
Post by eternally_troubled on Sun 16 Nov 2014, 2:28 pm
@Wildwards wrote:Thanks for all the info guys. Blimey! They are quite pricey those Renntec racks. Last time I bought a new one it was only about 30 quid.........mind you that was for a CX back in 1981. Ha!
I think Renntec have realised that they are onto a Good Thing(tm), plus I suspect there has been a wee bit of inflation since 1981!
I would guess so; if you are interested I would drop him a PM...
Post by Jameshambleton on Wed 31 Dec 2014, 8:14 pm
Managed to find one now /solved
    Current date/time is Tue 17 Jul 2018, 4:30 am
