cleaning tyre weld off wheel rim
Post by trevor machine on Wed 27 Aug 2014, 8:24 pm
Got a flat recently and had to limp home on rear tyre half filled with rubbishy Shell brand hole weld. Did fuck all tbh. Anyway, some found its way on to the wheel rim and now it's set like enamel. Nowt'll shift it. Smelled really strongly of acetone during in use - so am thinking nail varnish remover. But might that fetch some paint off at the same time. Probably not - but thought I'd ask before I give it a go.
Re: cleaning tyre weld off wheel rim
Post by sullivj on Wed 27 Aug 2014, 10:10 pm
That's annoying Trevor. I would be tempted to try 'sticky stuff remover' first (I'm not taking the p!ss - it really is called that).
If that doesn't work, try some nail polish remover, carefully as I expect you could lift the paint.
Post by trevor machine on Thu 28 Aug 2014, 10:47 am
Cheers - I'll see if I can get some of that stuff.
Post by ashcroc on Thu 28 Aug 2014, 12:52 pm
Alloy wheel cleaner may work though it will strip paint if left on long enough.
Alternatively if it's latex based like holts true weld hot water may work to soften it enough for removal.
Post by trevor machine on Fri 29 Aug 2014, 7:07 pm
Well, that's the least noxious approach - so a good place to start. Also, I'm cautiously optimistic too - I do reckon it will soften with a certain amount of heat. So nice one.
    Current date/time is Mon 23 Apr 2018, 11:43 pm
