Hi everybody.
Stooby2
Stooby2
Hi everybody. Empty Hi everybody.
Post by Stooby2 on Sun 13 Jul 2014, 3:17 pm
Hi all,
Just picked up a 2003 CB500S on eBay. It's a good runner but needs a bit of TLC, so it's now slightly dismantled on the workbench awaiting some parts. When I found the air filter was marked "fitted at 26, 500 july 07" I realised the PO was not quite as honest as he made out with the "well maintained" bit.
Still, it was cheap enough and will be fine after a few evening's work. I've only bought it for the commute into London everyday, which I'm sure it's ideal for.
GlenAnderson
GlenAnderson
Laser Shark
Laser Shark
Hi everybody. Empty Re: Hi everybody.
Post by GlenAnderson on Sun 13 Jul 2014, 7:30 pm
Hi there, and welcome.
Commuting is the kind of thing a CB500 excels at. I'm sure you'll not regret your purchase.
Post by eternally_troubled on Mon 14 Jul 2014, 12:42 pm
If you knock the spiders out of it and give it a vacuum then that air filter will be fine :)
Post by teamster1975 on Mon 14 Jul 2014, 10:19 pm
Welcome mate! The CB5 is a great little commuter, perfect for town work.
Do check the rad fan earth wire is in tact; fixes behind the top bolt on the rad fan and like to rust off.
Post by sullivj on Tue 15 Jul 2014, 6:54 am
Nice find. Air filter will be fine.
Post up a picture of your bike if you can.
Welcome.
Post by eternally_troubled on Tue 15 Jul 2014, 12:40 pm
@eternally_troubled wrote:If you knock the spiders out of it and give it a vacuum then that air filter will be fine Smile
On a more serious note, it is probably more important how many miles it has done - I don't really think they 'go off' too quickly but they can clog up with dust and dirt, so it might be more sensible to write the mileage on it, rather than the date.
Stooby2
Stooby2
Post by Stooby2 on Wed 16 Jul 2014, 5:54 pm
Thanks for the replies guys.
So far I've flushed out the cooling system and fitted a new  radiator (pattern) as the old one was shot. Checked the fan and that all works, had to redo the earth connection though.
Drained the oil out and refilled with some cheapo stuff then ran it during the coolant flushing,  then drained the cheap stuff out. New filter and decent oil are now in. And a new air filter has been fitted.  Very Happy
Stripped and rebuilt the front calliper as that was pretty stiff, pretty gunked up behind the seals, but all good now.
One of the fork seals is weeping so that will be done shortly and then head races need some adjusting while I'm there.
Then it needs a damn good run to the coast to blow the crud out of the carbs and engine.
My bike
Post by eternally_troubled on Thu 17 Jul 2014, 5:56 pm
Looks pretty good.
You shouldn't have a problem doing fork seals - there isn't anything particularly special about the forks on the CB500!
Where's 'the coast' near to you?
Stooby2
Stooby2
Post by Stooby2 on Thu 17 Jul 2014, 10:22 pm
Brighton is the closest part of the coast for me. Fork seal took about 20 minutes to do - I've done enough of them over the years and the CB500 is certainly one of the simpler ones.
Took it out for about 25 miles around the country roads, giving it a good rev through the range and it's now sounding a whole lot better, much smoother tickover. Runs pretty well, I just need to balance the carbs now and it'll do.
Post by teamster1975 on Thu 17 Jul 2014, 10:23 pm
Brighton, you can't be too far from me!
Stooby2
Stooby2
Post by Stooby2 on Fri 18 Jul 2014, 6:54 am
I'm in Croydon, abour a stone's throw from the Kent border.
Post by eternally_troubled on Fri 18 Jul 2014, 1:37 pm
You are miles from me: my nearest coast is probably Hunstanton!
Glad to hear it is sounding better after a good thrashing.
Stooby2
Stooby2
Post by Stooby2 on Fri 18 Jul 2014, 4:03 pm
Hmm...just found out it's got a charging fault as well. Good job it's a light bike that's easy to bump start.
That's tomorrow sorted then.
Post by teamster1975 on Fri 18 Jul 2014, 4:05 pm
@Stooby2 wrote:I'm in Croydon, abour a stone's throw from the Kent border.
Not far at all, we'll have to sort a "Southern CB500 ride-out" one of these days
Post by badseeds on Fri 18 Jul 2014, 8:16 pm
I'd be up for this. I live on the Suffolk/Norfolk border, but I'm a south Essex lad. And I love riding my bike!
    Current date/time is Thu 27 Jun 2019, 5:41 am
