Front forks CB500 97
Daniel Y
Post by Daniel Y on Tue 27 May 2014, 5:11 pm
Hi
Im needing complete forks for cb500 1997 model.  I just posted elsewhere then saw this "wanted" section!
Also advice if a 1994 set would fit even though calliper change from nissin to brembo...?
Re: Front forks CB500 97
Post by Beresford on Tue 27 May 2014, 5:21 pm
The CB500 racers tend to hoover them up, but they do appear from time to time on ebay.
http://www.ebay.co.uk/itm/Honda-CB500-CB-500-94-Front-Suspension-Forks-Read-Description-/181416373827?pt=UK_Motorcycle_Parts_13&hash=item2a3d422e43
I got a pair for a lot less than these - not needing seals either! - so keep watching and just be patient
Daniel Y
Post by Daniel Y on Tue 27 May 2014, 6:33 pm
Ah thanks for the info!  I wondered who was nabbing them... And I was checking out exactly those 94 set.  Glad to know it is poss to get the right ones.  Given time...
Post by ashcroc on Wed 28 May 2014, 4:25 am
The only difference is they changed the internal spacer length & oil volume a few times over the years plus the earlier sets will have a bolt near the base for easier draining.
Everything else where it matters is exactly the same so will fit all years.
    Current date/time is Tue 17 Jul 2018, 4:28 am
