How to unbolt the battery cover?
Pugzilla
Post by Pugzilla on Tue 20 May 2014, 5:11 pm
I won't be using the bike for a few months so I'm going to disconnect the battery.
What tools do I need to remove the bolt from the battery cover?
Re: How to unbolt the battery cover?
Post by teamster1975 on Tue 20 May 2014, 5:12 pm
It's a 12mm bolt from memory, I may be wrong, it's been a while since I undid it!
Post by eternally_troubled on Tue 20 May 2014, 5:54 pm
So, either you need a 12mm socket or wrench (if teamster is correct) or you could probably use an adjustable spanner if you had one handy. There may be a 12mm thingy in the CB500 tool kit - I don't know 'cos mine didn't come with one, but it would be worth a look if you have one.
Post by ashcroc on Tue 20 May 2014, 7:36 pm
Iirc the it might have Phillips head recesses too. The cable bolts certainly do.
jonny10
Post by jonny10 on Tue 20 May 2014, 8:58 pm
10mm socket. Hard to get a spanner on it (unless it's offset type) cos of the plastic mouldings around it.
Post by eternally_troubled on Thu 22 May 2014, 1:11 pm
I knew someone would have the right answer soon Smile
    Current date/time is Sat 23 Jun 2018, 1:38 am
