1994 headlight bolt fittings and gap.
HomeBrew
Post by HomeBrew on Mon 24 Mar 2014, 9:37 pm
I am fitting a 1994 headlight to my 1997 CB, I have connected everything up but there is a large 3mm gap around the glass allowing weather etc into the interior wires.
I have screwed on the 3 bolts that attach the rim and headlight to the case, there is one small bolt that secures the rim to the headlight in addition to spring adjuster one- I cannot attach this through the case as-well, as there is only a spring plate that takes the thread on the inside not attached to anything- there is a hole on the case which lines up with this bolt but how are you meant to screw a bolt through when there is no way of holding the plate from the inside?
I hope that is clear enough, on the 1997 headlight there is a nut welded onto the tab, so the bolt can just be threaded through.
Thank you for any insight.
Applecart
Re: 1994 headlight bolt fittings and gap.
Post by Applecart on Mon 23 Jun 2014, 5:55 pm
The 94 ( rounded bowl rim design ) and 97 onwards ( squared off rim design ) headlights are completely different.
The 94 glass is retained by a metal inner ring and the 97 onwards doesn't have this. I should really go take some photo's since a picture explains more than I can in words but I first have to figure out how to create and use my forum gallery, it's saying mine is full even though I've not uploaded anything into it yet!
Post by eternally_troubled on Tue 24 Jun 2014, 4:20 pm
It is often quicker/easier to use something like photobucket and/or flickr and put a link your picture into your post....
I think the 'storage limit' referred to is one for *the whole gallery* not your personal space - ie. someone needs to go in and delete some pictures. I should know how to do this, but...
Post by badseeds on Tue 01 Jul 2014, 7:27 pm
This headlight unit was also used on these other Honda machines. This is how it's fixed:
Unfortunately Honda don't list it with a seperate part number.
    Current date/time is Sun 18 Feb 2018, 8:18 pm
