Headlight Rim and Bowl
jimbobs63
Post by jimbobs63 on Mon 10 Mar 2014, 5:49 pm
Hello,
Has anyone one got a headlight rim and bowl for an unfaired CB500 that they don't need?  I don't need the actual lamps, glass, reflector, etc as these are working fine.
It's just the chrome surround that's in piss-poor condition with rust bubbling through.  So if you do have a spare headlight rim and bowl in decent condition, I'd be interested!
Thanks,
Jim
Re: Headlight Rim and Bowl
Post by Tricky. on Mon 10 Mar 2014, 8:01 pm
sorry cant help you with this but it reminded me about your radiator side pods, are they available yet?
cheers.
jimbobs63
Post by jimbobs63 on Mon 10 Mar 2014, 10:02 pm
Hi tricky,
Oh, yes! I finally got hold of one for the right side the week before last.
As I think I told you, they are in rough condition, and neither have the lugs, but if you can make use of them, you can have them.  I also have the two side panels as well in similar rough condition.
Jim
Post by badseeds on Mon 10 Mar 2014, 10:47 pm
What year CB500? R-T use part no. 33101-MG9-661 which is also used on these other Honda models and V-Y-2 use part no. 33101-MAK-000 which is used on these other Honda modes. You can use this information to widen your search.
Note: these part numbers are the rims only.
jimbobs63
Post by jimbobs63 on Tue 11 Mar 2014, 9:09 am
Hello Badseeds,
Thanks for the info!  That will help!!  I have a 1997/8-V model.
I would guess the bowl is similarly used on a range of other models.
Jim
    Current date/time is Tue 17 Jul 2018, 8:13 pm
