Swing arm pivot bolt caps
jonny10
jonny10
Swing arm pivot bolt caps Empty Swing arm pivot bolt caps
Post by jonny10 on Sun 16 Feb 2014, 12:00 am
One of mine fell off when cleaning the bike and it wasn't pretty in there. The bolt itself looks ok but the socket/recess in the frame, around the bolt, is a right rusty mess. I was able to pick out lumps of rust with my fingers! Not good. (rest of the bike is fairly rust free).
The teeth round the edge of the chrome cap are buggered too.
I've noticed a lot of CB's don't have these caps. Maybe they get lost or folks just take them off because all the cap seems to do is trap water in there - bad design.
Anyone else got this?
Swing arm pivot bolt caps Empty Re: Swing arm pivot bolt caps
Post by badseeds on Sun 16 Feb 2014, 2:02 am
Yep. I lost one and there's corrosion on both sides, just as you say. On removal of the other side, I was greeted with broken teeth on the cap. I plan to clean 'em up, smear with grease and fit VFR800 caps; simply because I have a pair.
Post by jchesshyre on Sun 16 Feb 2014, 3:32 am
Hmmm those caps are vaguely on my 'to buy' list, after I took apart and greased my swing arm bearings about a year ago and noticed they were missing. But they're eleven quid each!! I put some ACF50 on the bolts and they still seem fine. I'm on 145,000 miles with the original swing arm bearings. I reckon the caps are largely or even purely cosmetic.
Post by teamster1975 on Sun 16 Feb 2014, 9:22 am
I did actually replace mine a few years ago and the new ones are a really tight fit.
trevor2110
trevor2110
Post by trevor2110 on Sun 16 Feb 2014, 1:19 pm
Lost one of mine a few years back. Got another from from David Silver, think it was something extortionate around the £8 mark. Sod's law, I broke it trying to put it on. So I just filled the void with grease.
jonny10
jonny10
Post by jonny10 on Sun 16 Feb 2014, 5:59 pm
I just cleaned all the rust off & will prime and hammerite it. Don't think there's any point getting a new cap as there's nothing to hold it now
steady Eddy
steady Eddy
Post by steady Eddy on Sun 16 Feb 2014, 6:10 pm
One of mine was missing when i bought bike and there was loads of rust in the cavity. I used one of these from screwfix to clean it out, hammerited generously and it looked a lot better.
I have to agree its a bad design and the teeth on the cap are lame.
TimReal
TimReal
Post by TimReal on Sun 16 Feb 2014, 7:51 pm
Funny, today if noticed I've got one missing on both bikes, both on the same side.
Post by teamster1975 on Sun 16 Feb 2014, 7:55 pm
Both mine were pinched when I was parked in London, thieving barstewards  Evil or Very Mad
Post by eternally_troubled on Mon 17 Feb 2014, 12:41 pm
If you are not concerned with appearances a good dollop of grease in there will do wonders to keep the rust at bay, in fact, even if you do buy new caps a good dollop of grease would be a good idea...
Post by trevor machine on Tue 18 Feb 2014, 8:09 pm
My off-side one fell off a few months ago cos some of the retaining teeth had broken off - probably during a prior removal. A previous owner had somehow glued it back on (there was the remains of old glue around there). Which is of course exactly what I did. It's a shame they're made of such brittle plastic - if they were only a bit more flexible/rubbery they'd be great. Not sure what to do now. I'm toying with the idea of trying to ahem "fabricate" i.e. bodge some of my own black covers out of some old plastic, but I can't quite think how to, well, how to do it. Ehh.
Post by sullivj on Tue 18 Feb 2014, 9:25 pm
Hmmm, this sounds like somewhere I haven't yet cleaned...!
Should the caps just prise off?
jonny10
jonny10
Post by jonny10 on Tue 18 Feb 2014, 10:36 pm
@trevor machine wrote: Not sure what to do now. I'm toying with the idea of trying to ahem "fabricate" i.e. bodge some of my own black covers out of some old plastic, but I can't quite think how to, well, how to do it. Ehh.
If you can get it off again without wreckin it, why not just clean any rust out, prime & paint it, good dollop of grease like has been said above and then refit? Or, if it's beyond saving, just get a new one - after doing all of the above
Item 17 below
http://www.lingshondaparts.com/honda_motorcycle_parts_selection_pfk.php?block_01=13MY52I1&block_02=F__3000&block_03=1589
jonny10
jonny10
Post by jonny10 on Tue 18 Feb 2014, 11:06 pm
@sullivj wrote:Hmmm, this sounds like somewhere I haven't yet cleaned...!
They should but...the teeth that hold the cap on are weak and if any rust has happened in there (and I bet it has cos it's just a water trap), good chance it'll bend/deform the teeth, causing them to just snap off.
Good luck with the cleaning!
Post by sullivj on Wed 19 Feb 2014, 12:32 am
Thanks. I'll give it a go when I'm feeling brave and report back.
Post by trevor machine on Thu 20 Feb 2014, 5:03 am
Item 17 below
Well, I had this vague idea that I could make a better covering - out of plastic that is far more durable. Of course, it wouldn't be the nice "chromed" stock kind. Instead it would be black (whether by painting or simply because that's what colour the plastic was that I managed to fashion one from). My problem with this idea is thinking how to make "teeth" to retain the cover. But yeah - I will inevitably just end up buying some.
Post by Beresford on Thu 20 Feb 2014, 10:19 am
Swing arm pivot bolt caps $(KGrHqEOKpoE0UegnOKhBNYucf5Tpg~~_35
These from ebay might be suitable. What size is the hole they have to fit into ?
Post by trevor machine on Fri 21 Feb 2014, 6:25 am
Good find.  Wink
Haven't had chance to measure yet but I'm guessing between 40 and 50mm - and I see they do one of those caps at 45mm.
http://www.ebay.co.uk/itm/6-x-Plastic-Black-Blanking-End-Caps-Round-Tube-Pipe-Inserts-External-Diameter-/221124356712?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&var=&hash=item337c09ea68
Post by trevor machine on Fri 21 Feb 2014, 4:25 pm
Okay - I've tried a slightly more systematic form of measurement, and although I'm still not 100% certain what the precise diameter is I'm currently thinking it's slightly less than 45mm.
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Fri 21 Feb 2014, 7:47 pm
The correct measurement obtained by vernier caliper is 39mm
Post by Beresford on Fri 21 Feb 2014, 7:55 pm
40mm caps are available on ebay. They should suit as they are for 40mm OD tube with a wall thickness of 1-3mm
http://www.ebay.co.uk/itm/4-Black-Plastic-Blanking-End-Caps-For-Round-Tube-40mm-/280936332309?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item41691c3c15
If they were slightly loose an O ring slipped over them would grip and grease would be retained.
steady Eddy
steady Eddy
Post by steady Eddy on Sun 23 Feb 2014, 2:30 pm
Good find! Has anyone ordered or tried them yet?
Post by trevor machine on Sun 23 Feb 2014, 7:59 pm
I'll get some tomorrow, hopefully.
WeeTony
WeeTony
Post by WeeTony on Sun 23 Feb 2014, 9:16 pm
hey guys I bought these after seeing this, will post a pic when they arrive...
thanks
UKTyler
UKTyler
Three's a Charm
Three's a Charm
Post by UKTyler on Sun 23 Feb 2014, 10:25 pm
I wonder if these will fit?
http://www.ebay.co.uk/itm/Unissued-Unused-USGI-40mm-Bofors-Rubber-Barell-Protection-Cap-/360745371271?pt=LH_DefaultDomain_0&hash=item53fe198687
    Current date/time is Wed 22 May 2019, 2:23 pm
