osram Nightbreaker bulbs
oldenuff
Post by oldenuff on Tue 02 Nov 2010, 11:46 am
Just tried one of these. Much more light with a very white colour. List at £30 plus but a tenner plus post from http://www.norbsa02.freeuk.com
rossani
Re: osram Nightbreaker bulbs
Post by rossani on Sun 20 Feb 2011, 7:53 pm
Also Osram Nightbreaker Plus out now - £24 pair H4, delivered (though I guess someone will be doing singles.
These beauties last 50% longer than the standard Nightbreaker, but only a small uplift in price...
vinnyg
Post by vinnyg on Sun 27 Feb 2011, 3:33 pm
Any problems with melting/discoloured lens?
Been thinking about this for a while but would rather have a "dim view" than keep buying new headlights.
rossani
Post by rossani on Sun 27 Feb 2011, 3:45 pm
The bulbs don't run any hotter than normal as they're the same wattage, so no problem with melting or discoloration - just use as you would standard bulbs
Post by teamster1975 on Sun 27 Feb 2011, 3:54 pm
If that's the case I'll get one for myself as well. It can get quite hairy on country lanes in the dark with the stock lamp!
rossani
Post by rossani on Sun 27 Feb 2011, 4:04 pm
Good move, you'll definitely notice the difference. It's the Xenon gas that produces the brighter output, rather than any increase in wattage...
Globetrotter
Post by Globetrotter on Sun 27 Feb 2011, 6:49 pm
My CB has a Powerbronze fairing with Twin Lamps. I've just changed from stock Halogen to these Osram Nightbreaker... The Twin lamps were 1x 55/65 and one 35/35 watt... The only thing is it kept blowing the 10A fuse, so I now run on a 15A fuse instead...
One other snag was a broken wire at a connector, but that was the mechanic installing the bulbs...silly me!!!!
As for the Osrams, they're fantastic cheers
G-T
rossani
Post by rossani on Sun 27 Feb 2011, 7:19 pm
Interesting... if my understanding is correct a 10A fuse ought to be good for up to 120 watts max.
V=IR, Volts (12) = Amps x Resistance (Watts)
Globetrotter
Post by Globetrotter on Sun 27 Feb 2011, 7:23 pm
Indeed you are correct...
I didn't make myself clear...
I originally has 1x 55/65 Watt and 1x 35/35watt
I now have 2x 55/65watt - and when both full beam 65W 'ON' this totals 130W thus blowing the 10A fuse.
15A works a treat Smile
G-T
rossani
Post by rossani on Sun 27 Feb 2011, 7:26 pm
Yeah, that makes sense... 130 watts of light must be fantastic!
Globetrotter
Post by Globetrotter on Sun 27 Feb 2011, 7:27 pm
Yep - See me from the Moon.... Well probably not, but they're really bright... LOL
Basil Moss
Post by Basil Moss on Thu 25 Oct 2012, 10:34 pm
What size of these bulbs do I need?
Vexx
Post by Vexx on Fri 26 Oct 2012, 9:43 am
might have to check these bulbs out!
like the idea of a whiter light. best start saving...
Vexx
teamwindsor
Post by teamwindsor on Wed 12 Dec 2012, 8:37 am
@Basil They are H4 bulbs. Same design as the standard bulbs just with a bit more oomph!
Basil Moss
Post by Basil Moss on Wed 12 Dec 2012, 12:31 pm
Yeah, I got them - SO impressed! I can see where I'm going at night! Amazing!
    Current date/time is Sat 23 Jun 2018, 8:20 pm
