Coil upgrade
Coil upgrade - Page 2 Empty Re: Coil upgrade
Post by ANDYC on Wed 25 Jan 2017, 2:19 pm
I just happen to be breaking a 929 Fireblade at the moment, so I have two pairs of coils complete with connectors available at the moment.
£45 posted to UK mainland. Or £40 collected from the Windsor area.
Post by ANDYC on Wed 25 Jan 2017, 6:49 pm
One sold, just one left.
Post by ANDYC on Fri 27 Jan 2017, 7:09 am
All gone now.
cebecero
cebecero
Post by cebecero on Tue 11 Jul 2017, 10:58 pm
Hi!
amazing mod man. Just two weeks ago by surprise my bike starts to fail. Like she works only with one piston sometimes (lost power especially in low revolutions).
I read about this issue and founds maybe is a coils problem.
i dissamble the petrol tank and arrive to the old coils. Put off and measuring resistance. All is ok, but one of the sparks pipes dont measures the correct ohms specs all the times i take the measure (left motor side). I change for a new one (and put also a iridium NGK sparks) and mounts all again.
Now the motorcycle go really good again. Better than before, i think maybe the new iridium sparks.
And now i read this and i´m thinking, because now i know how to arrives to the coils and put off (i have not fear i want to say):
Maybe i put a new ones... If their fits well and works better like you say ANDYC is a really afair.
I´m spanish, and my english is not very good, and i have fear to make a mistake. You say the only thing i have to do is take off the old big coils from the frame (with their metal suport) and put this new from a CBR fireblade 2002/03 ??
The conexion are the same?? Only this two wires?? (i try to put one photo)
I disconect from the old ones and plug directly on the Fireblade??
Coil upgrade - Page 2 Img_2010
Thanks a lot... i love the idea of exploit more eficienly the caracteristics of our CB500...
Post by Jameshambleton on Wed 12 Jul 2017, 8:56 am
Hope these photos help when I installed mine.
Coil upgrade - Page 2 Y4mH8m6vbL9HW32sbxZNS9yopY_E_QqXHVzTZFZu35EXEjTD3Cj2HCgj7HBYbaOOWpMGLvtmbgf-ymRSXoBuLtYzJwg-LOMQiEztPBkBwZ-dtYmJ4CcGq4iHawH-tsF6VSC2jits5hmUHNiiTdQPKWDdwpspnj789cQH1S1OwRVQBUWxii7guQGU8Z5Xs-ib1MkWchRf2HvLvFAqtoyf2-uWQ?width=3096&height=4128&cropmode=none
Coil upgrade - Page 2 Y4mYZyM8jgtFO6rKs0TyqTVMB1vv3cXVNFKTONLW9CfWdH2HR0_wdz7Jmv3aR8_gRHIV8yB8Ssg5txydlDkNVWER9mpmu9_41L7pssXCvKgHpMz1VPmrt5c_NCMHn6icohlYICOU2D5ddanoa1X4sqBfAdmQdYbheb7usKxoCyKUNOHiWyoYqbaA2uYCGPU6M48ih0GRCufEa8BKXD_b6HFBg?width=3096&height=4128&cropmode=none
cebecero
cebecero
Post by cebecero on Wed 12 Jul 2017, 2:00 pm
Hi James
Thanks a lot, this photo solve all my doubts!!
Is like i think: is direct conect to the CBR coils. Easy and clean, love it.
This will be my next mod to the CB500....
Is working fine in your motorcycle, James??
Thanks again. Un saludo!!!
Post by Jameshambleton on Wed 12 Jul 2017, 7:16 pm
@cebecero wrote:Hi James
Andy can supply you the parts, such as the coils and the coil connectors. I had to crimp on some spade connectors and connect them into the loom. I've done about 6500KM since doing mine, with no issues to report.
Post by ANDYC on Thu 21 Sep 2017, 12:53 pm
I now have 2 pairs of CBR1000rr coils and connectors that should be available soon for any interested parties.
The connectors are new which look a lot better. Very Happy
£55 posted to you in the UK.
Stevie Gimo
Stevie Gimo
Post by Stevie Gimo on Tue 06 Mar 2018, 6:52 am
Ok, so I'm going to give this upgrade mod a shot. I've sorted out the right parts I think (HONDA CBR 954RR FIREBLADE 2002/2003 SC50 DENSO IGNITION COILS & LOOM).
With regards to the wiring I take it that basically remove the two wires from each existing coil, which are then connected to the 2 pin multi plug on the fireblade caps?
My thoughts are to unravel the fire blade loom & use as much of it as possible, & connect into the wires of the CB500 loom. Which wires are which? as I dont want to connect them the wrong way around I.E. send a + to an -
Regards
Steve
Post by ANDYC on Tue 06 Mar 2018, 8:25 am
The 954 fireblade has a separate sub loom for the coils so you can only get about 8 inches of the wires.
I can check on the wiring for you and I'll let you know tomorrow. My memory isn't what it used to be.
Stevie Gimo
Stevie Gimo
Post by Stevie Gimo on Tue 06 Mar 2018, 8:46 am
Ok, thanks ever so much
Stevie Gimo
Stevie Gimo
Post by Stevie Gimo on Fri 09 Mar 2018, 8:11 pm
Well the coil sticks arrived today, pulled all the old insulation tape off the loom (Hardest part of the whole process) to see what I had to work with. Choose the pair with the longest black/white wires & fitted them to their respective plugs to test. Fired up instantly, so will need to put them in on a more permanent basis.
A big thanks to ANDYC on this, who went above & beyond in my opinion, a true gent.
Grab yourself a virtual beer on me & many thanks too.
I've had a misfire at around 2000 rpm for some time now, kinda suspected a coil was breaking down, but alas still have the misfire. I need to start another post on this probably, but this upgrade is well worth doing even if your not having issues
So a big +1 on the upgrade from me
Steve
Post by ANDYC on Sat 10 Mar 2018, 3:32 pm
I now have 2 more pairs of cbr1000RR stick coils with new connectors up for sale.
£55 posted UK mainland or £50 collected from the Windsor area.
tt fan
tt fan
Post by tt fan on Sat 10 Mar 2018, 7:58 pm
I'll take a pair of these please Andy.
Any luck with the stainless engine bolts while we're at it?
I get down to Heathrow quite a bit so could collect all together if that's ok.
PM if you want to discuss further?
Post by stormbringer on Thu 29 Mar 2018, 6:50 pm
@ANDYC wrote:I now have 2 more pairs of cbr1000RR stick coils with new connectors up for sale.
If you've still got a pair for sale (and the CBR1000RR coils work similarly to the 954 coils) I'll be happy to buy them.
P&p to Denmark - you name a price.
Post by ANDYC on Thu 29 Mar 2018, 7:31 pm
I'm waiting for some more to come in, I'll let you know as soon as they do.
Post by stormbringer on Mon 02 Apr 2018, 12:03 pm
@ANDYC wrote:I'm waiting for some more to come in, I'll let you know as soon as they do.
Wunderbar Smile
Post by ANDYC on Wed 11 Apr 2018, 5:10 pm
I now have 4 sets of coils and connectors available.
You know that you want them!!!  Very Happy
burudis
burudis
Post by burudis on Fri 08 Jun 2018, 1:24 pm
jelou paisa! jir anoder spanis guiz 2000 cb500 reading you.
salud!
radicm
radicm
Post by radicm on Sun 02 Jun 2019, 11:02 pm
I've tried this upgrade with CBR 600RR (03-06) coils today and result is just wow you can really feel the difference.
This investment really payed off, thx ANDYC for sharing this with us.
    Current date/time is Sat 17 Aug 2019, 11:36 pm
