Honda CB500S to CB500 Conversion and other mods
Szabi
Szabi
Honda CB500S to CB500 Conversion and other mods Empty Honda CB500S to CB500 Conversion and other mods
Post by Szabi on Tue 26 Nov 2013, 8:33 pm
Hi All,
I have a 1998 Honda CB500S which I am very satisfied with, but thinking about converting into a Honda CB500 with the following mods:
-Remove front fairing
-Remove speedo
-Install Dominator Twin headlights
  Honda CB500S to CB500 Conversion and other mods 1456796_10202101648718847_712436477_n
-Install universal speedo
 Honda CB500S to CB500 Conversion and other mods 1459293_10202101678839600_1887232726_n
-Install Honda CB500 side covers
Honda CB500S to CB500 Conversion and other mods 1463679_10202101689279861_1851482875_n
-Install smaller indicators
-Install Handguards
-New mirrors
-Respray all body parts to matte black
I am trying to make the front of the bike look like the Buell XB12X Ulysses Adventure:
Honda CB500S to CB500 Conversion and other mods 1452509_10202101709440365_1764285785_n
I might also make the front fender look similar to the Buell and maybe a home made belly pan.
Has anyone tried anything like this before or has anyone ever converted a CB500S into a naked CB500?
Will the Honda CB500 side panels fit straight on to my bike?
Any info is welcome Wink
Many thanks
Szabi
Szabi
Szabi
Honda CB500S to CB500 Conversion and other mods Empty Re: Honda CB500S to CB500 Conversion and other mods
Post by Szabi on Tue 26 Nov 2013, 8:43 pm
I have found this awesome looking bike on the net:
Honda CB500S to CB500 Conversion and other mods 1460274_10202101839603619_1636425205_n
My plan is similar with a little bit less black and the Buell's headlight, handguards, etc
Post by sullivj on Tue 26 Nov 2013, 8:46 pm
The side panels screw onto the radiator and tank.
Make sure your tank and rad have the right holes.
Post by muttley1 on Tue 26 Nov 2013, 8:50 pm
LOt of effort then, if you are changing the front perhaps go for a Powerbronze Venom : http://www.powerbronze.co.uk/822852/818248/---VENOM.model
m1
glen.wilson1@gmx.com
Post by glen.wilson1@gmx.com on Tue 26 Nov 2013, 9:06 pm
Let me know how you get on with the lights and speedo. Very Very interested in how easy/hard they are to fit. Would love to ad them on mine next year. Im after a new seat cover too something a bit more upmarket.
Post by badseeds on Tue 26 Nov 2013, 9:33 pm
Them Dominator lights are shite; look shite, made shite - out of shite, work shite - shite spread of light. They're just shite. Avoid!
Post by sullivj on Tue 26 Nov 2013, 10:15 pm
@badseeds wrote:Them Dominator lights are shite; look shite, made shite - out of shite, work shite - shite spread of light. They're just shite. Avoid!
Would I be right to assume that you're not keen on them?! rendeer
Post by badseeds on Tue 26 Nov 2013, 10:53 pm
Have you tried them? Shite, lad.
Szabi
Szabi
Post by Szabi on Wed 27 Nov 2013, 10:59 am
Well, that's a shame. I will probably consider different headlights then.
The bike is being used every day for the next few weeks, so I won't start this project. After that I will be starting at my new work and will cycle most times sot the Honda can be off road if needed.
Are the front forks and the handlebar the same on the CB500 as it is on the CB500S?
Thanks for all the info Wink
Post by eternally_troubled on Wed 27 Nov 2013, 1:24 pm
Yes, as far as I know, the forks are certainly the same diameter.
What you are planning is do-able; it just might take a little time and fiddling to get it spot on!
It is *possible* to make headlights in that shape that do work; you just need to find out which brand is best!
Post by badseeds on Wed 27 Nov 2013, 1:44 pm
You could always get some twin headlights off another bike. Perhaps VFR400Z, if there's one being broken on ebay. Would be cheaper, too.
Post by Beresford on Wed 27 Nov 2013, 5:06 pm
The top yoke and method of bar mounting are different. The 'S' bar has resilient mountings and the naked bars are rigidly mounted. Have a look at the parts diagrams in the 'Stickies' section
Post by glen.wilson1@gmx.com on Wed 27 Nov 2013, 7:30 pm
Can I just confirm the dominator lights are shite?Laughing
Does this go the same for other twin street fighter lights then?
Post by ANDYC on Wed 27 Nov 2013, 10:17 pm
The lower yoke is also different, they have a different offset and holes to mount the headlamp bracket frame.
UKTyler
UKTyler
Three's a Charm
Three's a Charm
Post by UKTyler on Wed 27 Nov 2013, 10:28 pm
I've always fancied a twin headlight set up, but not at the expense of seeing at night.
A lot of the cheaper twin headlights are complete rubbish. And if they are not and both lights are on at the same time you will need to fit a relay, because two 60w bulbs are likely to melt the wiring.
The stock CB light is one of the better lights out there, I'm still looking for a clear glass unit from a later Honda, but until then I'll stick to the standard light and an Osram bulb.
ryancook1993
ryancook1993
Post by ryancook1993 on Wed 27 Nov 2013, 11:58 pm
Why not fit a number board and fit a projector in the centre, its what I plan on doing to my nekkit cb5.
Szabi
Szabi
Post by Szabi on Thu 28 Nov 2013, 12:28 pm
Sorry if being dumb, but what is a 'number board'?
I was considering also projectors instead of Twin headlights, or as badseeds suggested- get a decent twin headlight from a different bike.
The only issue is how to fix the light to my forks/yoke and how to hide all the wires.
ryancook1993
ryancook1993
Post by ryancook1993 on Thu 28 Nov 2013, 12:49 pm
Yeah you would have to make a mount for the light, pretty easy really. The wires would probably be the main issue!
Honda CB500S to CB500 Conversion and other mods Screenshot_2013-11-28-12-46-06_zpseeaab2de
One number board ^^
Szabi
Szabi
Post by Szabi on Thu 28 Nov 2013, 5:52 pm
Thanks for clarifying Wink
Szabi
Szabi
Post by Szabi on Thu 28 Nov 2013, 8:55 pm
This also looks quite good I think:
Honda CB500S to CB500 Conversion and other mods 1476667_10202117047023795_2082734948_n
Honda CB500S to CB500 Conversion and other mods 1459332_10202117045703762_1547686502_n
Szabi
Szabi
Post by Szabi on Tue 07 Jan 2014, 9:23 am
After reading lots of reviews of aftermarket headlights on the net I think I can say that they are complete rubbish and I will be using a standard 7" round headlight.
Any of you guys have an unwanted standard round headlight unit for sale?
Post by sullivj on Tue 07 Jan 2014, 10:04 am
I've got a spare that came as a job lot with some other parts I bought. It's not 100%, but it works.
Honda CB500S to CB500 Conversion and other mods B89e450e71e8e1296d6c347c0e6bf4c1_zpsd745b3ce
Honda CB500S to CB500 Conversion and other mods 7320e33d348d887ee421703d70c120b3_zpsba87db15
Honda CB500S to CB500 Conversion and other mods E2779291678e23ebe93a9a3f6f2f06f8_zpsa36436bc
Honda CB500S to CB500 Conversion and other mods 23f1c13f58f90bfe3a17a240057b28a8_zpsaf2f8c88
Make me an offer if you're interested.
Cheers.
Szabi
Szabi
Post by Szabi on Tue 07 Jan 2014, 11:27 am
Sullivj, PM sent Wink
Szabi
Szabi
Post by Szabi on Thu 09 Jan 2014, 10:52 pm
I've got a nice n headlight now thanks to Sullivj Wink
I got lucky with the headlight, I'll try it again Smile
Does anyone has maybe a pair of CB500 tank side covers? Or tank fairings? -not sure what's the official name of it
    Current date/time is Wed 21 Aug 2019, 7:07 pm
