Specs/Stats
spitonyourgrave22
Specs/Stats
Post by spitonyourgrave22 on Sat 30 Oct 2010, 5:56 am
General information
Model: Honda CB 500
Year: 2003
Category: Naked bike
Rating: 67 out of 100.
Engine and transmission
Displacement: 499.00 ccm (30.45 cubic inches)
Engine type: Twin
Stroke: 4
Power: 57.00 HP (41.6 kW)) @ 9500 RPM
Torque: 46.00 Nm (4.7 kgf-m or 33.9 ft.lbs) @ 8000 RPM
Bore x stroke: 73.0 x 59.6 mm (2.9 x 2.3 inches)
Gearbox: 6-speed
Transmission
Final drive: Chain
Physical measures
Dry weight: 173.0 kg (381.4 pounds)
Seat height: 775 mm (30.5 inches) If adjustable, lowest setting.
Overall length: 2,090 mm (82.3 inches)
Overall width: 720 mm (28.3 inches)
Chassis and dimensions
Front tyre dimensions: 110/80-17
Rear tyre dimensions: 130/80-17
Front brakes: Single disc
Rear brakes: Single disc
Speed and acceleration
Power/Weight ratio: 0.3295 HP/kg
0-60: Around 4.5 seconds (Subaru Impreza)
Other
Fuel capacity: 18.00 litres (4.76 gallons)
Re: Specs/Stats
Post by Jameshambleton on Thu 03 Nov 2016, 8:42 am
Honda CB 500
Years: 1994 - 2003
Engine type: DOHC Twin
Gearbox: 6-speed
Transmission - Chain
Pitch:525
Links 108
Front sprocket: 15 teeth - JTF297
Rear sprocket: 40 teeth  - JTR1332
Physical measures
Seat height: 775 mm
Wet weight: 203kg
Front tyre : 110/80-17 120/70-17
Rear tyre : 130/80-17 130/70/17 140/70-17
Engine mounting bolts
Front: M10X260
Front with crash bars: M10X270
Upper rear: M10X165
Lower rear: M10X270
For replacement parts see Andy's thread http://www.cb500club.net/t4612-stainless-engine-mounting-bolts-and-alloy-spacers
Brakes
Front brake: Single 296mm disc 93-03
Rear brake: Single 240mm disc   97-03
Drum brake 94-96
Spark plugs
NGK CR9EH-9
NGK CR8EH-9
electrode gap 0.8mm - 0.9mm
Carb Jet sizes
Pilot 38
main 122
Air filter
K&N HA-5094
Oil filter
Hiflo 303
K&N 303
Fuel tank
Fuel reserve: 2.5 litres , personally I get 0.5 litres
Fuel hose: Inside 8 mm Outside 13 mm length 255 mm
Vacuum hose: Inside 3.5 mm Outside 8mm length 210mm - slightly longer maybe preferable
Forks
37mm - Note: stanchions sold by m&p are not compatible - ones sold by wemoto are
Fork seals dimensions 37x50x11mm
Handlebars
Renthal 759 bars fit with no alterations, 755 and 756's don't easily due to cabling issues
Rear shocks
Hagon -
Tec - these are slightly longer than stock so when the bike is on the main stand both wheels stay on the ground. These are better than Hagon as they don't rust throughout winter riding.
Battery
ytx9-bs
Bulbs
Headlight h4 55w
Clocks -  naked model maybe different for the faired version? 12v 3w t10
Indicator bulbs need to be 21w for correct flash rate
tail light 12v 21/5w dual filament bulb
Sump plug
M14 x 1.5
Re: Specs/Stats
Post by eternally_troubled on Thu 03 Nov 2016, 6:20 pm
Cool! Thanks for the update/improved states.
Re: Specs/Stats
    Current date/time is Sun 24 Jun 2018, 7:29 pm
