Simmi Exhausts
hs126783
hs126783
Simmi Exhausts
Post by hs126783 on Fri 08 Nov 2013, 9:59 am
Has anyone fitted a Simmi can to their CB? Are they as good as/better than Fuel?
Re: Simmi Exhausts
Post by muttley1 on Fri 08 Nov 2013, 7:51 pm
best answered on the racing site, think they are the manufacturer of choice for the track.
Doubt there's anything in it as on 50 odd bhp to play with. Lot of micron aftermarket cans around - some with link pipe to exit on the left (= removing pillion pegs and centrestand) but some exit on the right. Bigger jets a good idea as is a carb balance.
m1
hs126783
hs126783
Re: Simmi Exhausts
Post by hs126783 on Fri 08 Nov 2013, 9:36 pm
Thanks, I had seen good reviews of Fuel but none of Simmi
hs126783
hs126783
Re: Simmi Exhausts
Post by hs126783 on Wed 15 Jan 2014, 4:16 pm
Well, I finally bought and fitted a Simmi end can. Having read reviews on this and other forums regarding all options, the choice came down to Simmi or Fuel, and, believe it or not the final decision was taken to go for Simmi because I preferred their logo on the can. I went for a 400mm stainless oval can on the advice of Jeff at Simmi, and having ridden a few hundred miles, I can report the bike sounds (much) better, is slightly "fluffy" below 2500 RPM but goes much better thereafter and, if anything, is  slightly more fuel efficient than before!
Davie J
Davie J
Re: Simmi Exhausts
Post by Davie J on Fri 07 Feb 2014, 9:17 am
Good stuff.
Looking at one of these cans myself as mine is starting to develop a couple of pinholes near the first weld.
You running with the DB killer in or out?
hs126783
hs126783
Re: Simmi Exhausts
Post by hs126783 on Fri 07 Feb 2014, 11:09 am
Hi Davie, I'm running with the baffle in, which produces a satisfying, not too anti-social sound!
Davie J
Davie J
Re: Simmi Exhausts
Post by Davie J on Mon 24 Mar 2014, 9:10 am
I see what you mean about running with the baffle in Smile
I went for a 400 Oval as well based on what Jeff told you.
Really could have done with a P type strap tho.
Does yours pop on the over-run quite a lot? Not sure if that's normal or if it's because of the K&N Filter.
hs126783
hs126783
Re: Simmi Exhausts
Post by hs126783 on Mon 24 Mar 2014, 9:56 am
It does pop a lot, but I quite like that!
Davie J
Davie J
Re: Simmi Exhausts
Post by Davie J on Mon 24 Mar 2014, 1:09 pm
Good, I was wondering if I might need re-jetting.
Suppose you might if your running de-baffled.
hs126783
hs126783
Re: Simmi Exhausts
Post by hs126783 on Mon 24 Mar 2014, 1:54 pm
I took the plugs out of mine at the weekend, they were a nice light brown/grey colour, so mixture can't be far off
Davie J
Davie J
Re: Simmi Exhausts
Post by Davie J on Mon 24 Mar 2014, 3:37 pm
That's good to hear.
From what I've read elsewhere it's only when you change the full system you need a re-jet. Must be a slight change in downpipe diameter that messes with the backpressure.
Re: Simmi Exhausts
    Current date/time is Sun 24 Mar 2019, 7:25 pm
