Appearance
spitonyourgrave22
spitonyourgrave22
Appearance Empty Appearance
Post by spitonyourgrave22 on Sat 30 Oct 2010, 5:11 am
Pro Bolt
Pro Bolt
Here are nuts of all shapes, sizes and colours. Sorry...I had to say that. But really that is what Pro-Bolt are all about- tarty anodised bits and bobs for your machine. You can buy them in packs specific for your machines, or just buy what you need. And they actually have usefull nuts too- you can buy stainless steel replacements aswell.
Also buy resevoir caps, bar ends, yoke caps, cable adjusters, dust caps, sprocket nuts. The list is endless.
Indicators
(Hein Gericke)
Mini-indicators are a common and very cheap mod, as the standard ones are pretty hideous. You need the long-stem variety for the front on faired models. Make sure they are E marked or you won't pass your MOT. It's also a good idea to buy indicators that other road users can see, so you don't get run over. We all hate the twat who doesn't indicate.
If you buy LED indicators then youll need a resistor in the line so they flasher at the correct speed. Bulb replacements are a lot cheaper. You can buy these from anywhere, but Hein Gerike have a massive range, and they only stock road legal varieties.
If the indicators are too close to the headlight you can't see them!
[Fr33flow]
    Current date/time is Sun 21 Apr 2019, 11:10 pm
