WANTED
cb1300rider
WANTED
Post by cb1300rider on Sun 29 Sep 2013, 2:55 pm
Hi there
Does anyone have a set of crash bars including fittings cluttering up their garage?
Cosmetics not important, i'm happy to rub down and spray
Re: WANTED
Post by badseeds on Sun 29 Sep 2013, 6:30 pm
Be aware that you will also need a correct engine tie-bolt. I'm in exactly the same position. Bolt needs to be 300x10mm for the crash bars to mount at the front. Original is only 280mm long. I need to get one made.
cb1300rider
Re: WANTED
Post by cb1300rider on Sun 29 Sep 2013, 6:43 pm
Interesting
thanks for the hint
flashs
Re: WANTED
Post by flashs on Wed 20 Nov 2013, 1:45 pm
If its cheap you want.....    you can always drill a small hole in the lug just in front of the main through bolt, and mount the brackets to there (as I have, and been dropped on its side with no probs too) I couldn't shift the main bolt either so it's staying where it is till it's necessary lol
I have a couple of tatty but sound crash bars for sale ( a couple of brackets with them but you'll need to make the others... should be easy enough!)
 Cover postage... and donate a suitable amount to my fund please...    http://atwi80m.blogspot.co.uk/
Re: WANTED
    Current date/time is Mon 22 Jan 2018, 11:54 pm
