Air Filter Mods
KarDvy1405
KarDvy1405
Air Filter Mods
Post by KarDvy1405 on Fri 20 Sep 2013, 7:22 pm
Hi, i'm looking for a little guidance. I've just purchased a '96 CB500 which has a Fuel exhaust fitted. I'm thinking of ditching the standard airbox & replacing it with individual K&N clamp on filters. What size is the external dimensions of the carbs. Once fitted i'm going to get the bike set up on a dyno. What type of improvements should I see?
Re: Air Filter Mods
Post by badseeds on Fri 20 Sep 2013, 8:38 pm
Bugger all. You won't gain any more power by ditching the airbox. The only thing that will increase is your fuel bill. Stick a K&N in it and NGK Iridium plugs.
Re: Air Filter Mods
Post by eternally_troubled on Mon 23 Sep 2013, 1:06 pm
Well, K&Ns bank balance will improve Wink  I suspect that might be all.
There are probably things you can do to the airbox to tune it better/differently, but removing it all together isn't a good plan.  There was a thread recently on here with some modification ideas...
Re: Air Filter Mods
    Current date/time is Sun 24 Mar 2019, 7:11 pm
