2nd air filter change (with pics)
2nd air filter change (with pics) Empty 2nd air filter change (with pics)
Post by sullivj on Sat 10 Aug 2013, 4:15 pm
Finally had a bit of time this afternoon, so started tinkering with the bike...
Whilst I had the tank off, I changed the second air filter.  It sits in a black plastic case, just on top of the rocker box cover.  You can see how the old one was starting to perish.  They're only a couple of quid from Honda, so if you haven't done yours, maybe you should - it only took 20 mins.
2nd air filter change (with pics) Null_zps58804ba2
2nd air filter change (with pics) Null_zps82d374bc
2nd air filter change (with pics) Null_zps903984bc
HomeBrew
HomeBrew
2nd air filter change (with pics) Empty Re: 2nd air filter change (with pics)
Post by HomeBrew on Sat 10 Aug 2013, 9:52 pm
Couple of quid? Where did you buy it from? It is £8 at lings!
Post by sullivj on Sat 10 Aug 2013, 10:04 pm
My mistake, it wasn't a couple of quid - it was £5.51 + VAT.  Compared to the other bits I got, it didn't seem too expensive!
Post by eternally_troubled on Thu 15 Aug 2013, 1:43 pm
It will probably last for another 10 years, so that price isn't too bad...  if you have some air-filter foam (usually used in older/smaller bikes) and some scissors you can make your own.
Cheers for posting the photos/info....
Hcb
Hcb
Post by Hcb on Sat 09 Sep 2017, 10:00 pm
Where do you buyed It??
I'm searching It on many websites and its impossible.
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Sun 10 Sep 2017, 12:48 am
@Hcb wrote:Where do you buyed It??
Item number ten on Honda schematics for air cleaner, part number 17254KAZ000, available from David Silvers and other parts dealers
Post by stormbringer on Sun 10 Sep 2017, 3:02 pm
Go to local Honda dealer.
Buy.
Job done.
hh_12345
hh_12345
Laser Shark
Laser Shark
Post by hh_12345 on Sun 10 Sep 2017, 8:04 pm
Sheets of foam are sold cheap as air filters for scooters. You can get one and cut a piece to use for the cb.
    Current date/time is Tue 17 Sep 2019, 7:40 am
