Wobbly Side Stand
freeride
Wobbly Side Stand
Post by freeride on Sat 25 May 2013, 10:32 pm
I have a wobberly side stand. It moves sideways when loaded slightly as if the jaws are wider than normal or the hole in the frame is slightly bigger than it should be.
Any ideas-take it off and vice it together to see if this improves it? Can you get new springs on their own and also can you get the springs only for the riders foot pegs?
Re: Wobbly Side Stand
Post by teamster1975 on Sat 25 May 2013, 11:19 pm
I've got a similar problem with mine; all the years of use have worn both the bolt hole & the lug that the springs hook onto on the frame.
All that can be done is to get the hole filled with weld & re-drilled; have a look under the bike at where the springs hook on; if it's anything like mine there won't be much left. This is potentially bloody dangerous as you can imagine the spring coming unhooked while you're riding!
Post by Tricky. on Sun 26 May 2013, 12:13 am
@teamster1975 wrote:All that can be done is to get the hole filled with weld & re-drilled;
put a bigger bolt in.
Post by teamster1975 on Sun 26 May 2013, 8:52 am
If you can keep it centred; it may have worn a slot. I know for sure the lug that holds the spring on mine is virtually gone so there should be the same amount of wear in the bolt hole in the frame. Camera later!
louis_sutton
Post by louis_sutton on Wed 27 Jan 2016, 10:46 pm
Hi all - sorry to resurrect an old post (but I figure better that than a brand new one).  I think I'm in a similar situation.  I assume the side stand is not meant to move under load, so from the look of it, it has worn away the bracket on which it mounts.  Are there any other solutions beyond filling with weld and re-drilling?
I don't suppose you can buy a replacement bracket to mount the sidestand?  (I'd go and look, but I'm on tiny offspring patrol so can't slope off to the garage...)
Post by Guest on Thu 28 Jan 2016, 5:20 am
Add a bushing of some sort?
davebike500
Post by davebike500 on Thu 28 Jan 2016, 7:34 am
The side stand as you lower the bike onto it should move a bit it is kind of  a lock system
But it should not be a lot !
louis_sutton
Post by louis_sutton on Thu 28 Jan 2016, 1:28 pm
Hmmm, thanks gents. Might be overreacting. There's definite movement, so I'll keep an eye on it!
Post by sullivj on Thu 28 Jan 2016, 9:02 pm
Mine moves this much, which I think is 'normal'.
Thanks to JerryFudd for getting my video to work!
Post by skyrider on Thu 28 Jan 2016, 9:13 pm
yea I think that's as much as mine moves as well which I reckon is normal
Post by Jameshambleton on Thu 28 Jan 2016, 9:53 pm
Mine is about the same as that too!
Post by sullivj on Thu 28 Jan 2016, 10:01 pm
Interestingly, my CBF600 one doesn't move at all..
louis_sutton
Post by louis_sutton on Thu 28 Jan 2016, 11:19 pm
Thank god for that. Really appreciate it, I only noticed mine when parked on my drive (steep angle). Could do without anything else to add to the to do list.
You've put my mind at rest, many thanks
Post by sullivj on Fri 29 Jan 2016, 6:17 am
@louis_sutton wrote:Thank god for that. Really appreciate it, I only noticed mine when parked on my drive (steep angle). Could do without anything else to add to the to do list.
You're welcome.
Post by jerryfudd on Fri 29 Jan 2016, 9:55 am
I'd of thought there would have to be some give in it so that the repeated motion didn't start wearing the frame mount down, also if it where very rigid any movement would be transferred to the frame weld which can't be good so I would have thought you're fine.
    Current date/time is Sat 24 Feb 2018, 12:18 am
