OE Honda luggage rack
cb1300rider
Post by cb1300rider on Wed 15 May 2013, 8:50 pm
Hi there
I managed to pick up from a car boot an OE luggage rack. Problem is, it never had the spaces with it for fitting.
Looking at the pic above, can any one tell me the size of the spaces required please.
I dont see the point in the one labelled #8.
However #6 is critical in making the luggage rack secure.
Your help would be much appreciated.
Simon
cb1300rider
Re: OE Honda luggage rack
Post by cb1300rider on Wed 15 May 2013, 8:51 pm
Last edited by teamster1975 on Sun 19 May 2013, 2:11 pm; edited 1 time in total (Reason for editing : Fixed the image link)
cb1300rider
Post by cb1300rider on Wed 15 May 2013, 8:54 pm
Sorry, having difficulty uploading a picture again. If the above links dont work let me know
WeeTony
Post by WeeTony on Wed 15 May 2013, 8:59 pm
I will send a pic and measurements tomorrow if noones got back to you, I've just removed my rack.
They are approx. an inch wide (size of hole), 20mm long, and have space for an 8mm thread bolt to get through, they're also weighted.
cb1300rider
Post by cb1300rider on Thu 16 May 2013, 10:29 pm
Hi Weetony
If you can help out i would appreciate it.
Simon
WeeTony
Post by WeeTony on Fri 17 May 2013, 9:20 pm
Here you go dude...
Not sure how to go about ordering replacements, I'll be sending these with the rack I'm selling on ebay.
DOn't think you'd need them for the original grabrail.
Here's a pair on ebay that might work, worth a bash for £3.
ebay find
gaucho
Post by gaucho on Sun 19 May 2013, 2:10 am
Hi! I've got the same rack.
#6 very important, black, goes between rack and the part shown in the previous message.
#8... ¿kind of thick washer?, uncoloured, goes under seat.
Tomorrow morning I measure them and I tell you (raining here, bike is far, sorry). What is VERY important: rack is fine, quite strong, I use it every day with givi top box. The problem is bolt #7, better to replace the honda originals with 100% steel ones. I strongly recommend you, my ones broke with heavy luggage on rough road and almost broke the plastic tail (and it's a pain in the a.. to take the broken piece out off the frame)
cb1300rider
Post by cb1300rider on Sun 19 May 2013, 7:01 am
@WeeTony wrote:Here you go dude...
ebay find
Hi Weetony
THanks for taking the time to take pictures and post. THat item you have pictured, is that number 6 or 8 in my original post picture? Or is that #9 in this link here? My part #9 on grab rail looks very similar to what you have posted.
cb1300rider
Post by cb1300rider on Sun 19 May 2013, 7:02 am
http://www.lingshondaparts.com/hpl/images_large/13MY5WEA/imge/F__1400.jpg
#9 here sorry
for got to add to previous post
cb1300rider
Post by cb1300rider on Sun 19 May 2013, 7:05 am
@gaucho wrote:Hi! I've got the same rack.
Hi Gaucho, dimesions / pictures would be great.
I was planning on replacing with stronger bolts anyway. is #8 washer important?? i realise #6 is as this is needed to take up the space between grab rail and rack . . . your help would be appreciated
Post by ashcroc on Sun 19 May 2013, 12:18 pm
I haven't seen the OE racks in the flesh but if your lucky the ones you have for the grab rail (#1 & 2 here) may be enough. It all depends if the rack follows the line of the grab rail without the need for external spacers between fairing & rack. If you do need a spacer any machine shop should be able to knock a couple up quite cheaply (or do it yourself) once you have the dimensions.
As for #8, it's not so important but a large stiff washer will spread the torsional forces from a loaded up rack/top box.
WeeTony
Post by WeeTony on Sun 19 May 2013, 3:56 pm
what i've pictured is no.9 on the second pic, however, it was used as no.6 on the first pic on the installation of the givi rack i removed from my bike, where it was for a number of years and kilos.
no.10 is rubber and fits snuggly round the spacer.
gaucho
Post by gaucho on Mon 20 May 2013, 5:24 am
I'm not pretty sure -because of my poor english- but I feel I'm starting to realize what is happening: You should to take the original grab rail out (the grey one that comes with the bike) and replace the entire part with the new rack. Passenger now will use rack sides as grab rails.
Here the pics:
The Big pic: (Don't look to my bike left side because I lost spacer and guide and I had to improvise with car parts)
Only bike's Right side:
Rigth Spacer #6 (along with collar guide & rubber that come with bike)
Rigth spacer #8
Dimensions:
spacer #6 (black): 20mm diam, 8mm thick
spacer #8: 20mm diam, 5mm thick
As you may see in pics, I added steel bolts and split washers to make sure they don´t break or loose again.
cb1300rider
Post by cb1300rider on Tue 21 May 2013, 6:24 pm
Cheers for your help guys, I will be sorting while i am off this week.
THanks again
    Current date/time is Fri 23 Feb 2018, 6:25 am
